5th gear scratching
Old Dec 31, 2004 | 12:07 PM
97B18C5civic's Avatar
Default 5th gear scratching
ok, it seems like ive been posting in here more than ive wanted to, but when i got into 5th gear it scratches, no matter what range rpm im in, it use to do it when i would be in high rpm around 6-7k, but i just drove it down the road and i was shifting at like 2500rpm, i have a gsr tranny and the car use to be automatic, anyone else encountered this problem before because i really dont wanna take it in and be checked if its somethin i can do myself
Old Dec 31, 2004 | 02:40 PM
8krdline's Avatar
Default Re: 5th gear scratching (97B18C5civic)
sounds like the syncros are going
Old Dec 31, 2004 | 08:50 PM
Default Re: 5th gear scratching (8krdline)
ok this is my first honda ever and im still learning, now would this be hard to replace, i know i would have to take my tranny out but im not sure what syncros are, and ive searched on here and im still lost, any can direct me where i can read up on it or if its easy to explain if someone could tell me what it is
Old Jan 1, 2005 | 06:28 AM
ogabudiah's Avatar
You are better off buying a new tranny. Cost wise that is, it just isn't worth it.
Old Jan 2, 2005 | 08:09 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
yeah definitely the synchro. either the mesh is completely flattened and not pointed and/or the sleeve is severly binding on the hub (scarred up) and doesn't slide up and down smoothly. unless you can swap it out or find a knowledgeable person to work cheap for you then you are gonna pay a lot of moolah.
Old Jan 3, 2005 | 12:03 PM
Default Re: 5th gear scratching (not so civic)
hmmm, well thanks for the info ppl, not what i wanted to hear but now i have an idea of whats wrong, guess ill start checkin with ppl to see how much they will charge for work and stuff
blacK_Dc4
Apr 10, 2008 10:40 AM
OliGSR
May 27, 2005 06:14 PM
fangtl
Oct 4, 2003 06:19 PM
squirrel
Feb 19, 2003 09:12 AM
