3rd and 5th gear grinds??? someone help
Old Aug 9, 2006 | 09:05 PM
nek9's Avatar
Default 3rd and 5th gear grinds??? someone help
i change my trany oil yesterday and for some reason every time i go 4000rpm or higher my 3rd and 5th gear grinds? I put 2 1/2 oil in it ... can someone help me....
Old Aug 9, 2006 | 10:00 PM
Enzo Speed's Avatar
Default Re: 3rd and 5th gear grinds??? someone help (nek9)
Did you add fluid to the filler hole until it started to run back out?
Old Aug 9, 2006 | 10:26 PM
nek9's Avatar
Default Re: 3rd and 5th gear grinds??? someone help (Enzo Speed)
yea i did but alot spilled cuz i had a hard time putting the plug back in it was on a wierd angle but i put some more in .... can it be because the fluid wasnt tick enough should i add some lucas or something...
Old Aug 9, 2006 | 11:19 PM
Enzo Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nek9 &raquo;</TD></TR><TR><TD CLASS="quote">yea i did but alot spilled cuz i had a hard time putting the plug back in it was on a wierd angle but i put some more in .... can it be because the fluid wasnt tick enough should i add some lucas or something...
How does it spill out? If it spills out at all it means there's too much.
And don't add Lucas!
Old Aug 10, 2006 | 05:42 AM
nek9's Avatar
it just spilled out like normal like it means that its full.... but can it be that i use the the wrong oil or someting cuz i use royal purpule snycromas (i think i spelled that wrong)
Old Aug 10, 2006 | 05:40 PM
kameleon23's Avatar
was the car level when you filled it? I saw that you said it was on a weird angle. Car needs to be level to achieve the right amount
Old Aug 10, 2006 | 06:31 PM
nek9's Avatar
Default Re: 3rd and 5th gear grinds??? someone help (kameleon23)
the car was level and i add somemore fluid today just to make sure i put enough but it still grinds i dont really knowwats going on the only thing i can think off is that the fluid is to not tick enough for my tranny....and the trany is a b16 if the matters at all....
Old Aug 10, 2006 | 08:08 PM
B18c5__Owns's Avatar
From: I Bet You Really Want To Know Where In, NJ, USA
Gm syncromesh works wonders
just my .02
Old Aug 11, 2006 | 12:02 AM
Enzo Speed's Avatar
Default Re: 3rd and 5th gear grinds??? someone help (B18c5__Owns)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18c5__Owns &raquo;</TD></TR><TR><TD CLASS="quote">Gm syncromesh works wonders
just my .02</TD></TR></TABLE>
Yeah but the grinding started after the fluid change. Like he messed something up.
Old Aug 11, 2006 | 05:18 PM
turbolsvtecalwaysbroken's Avatar
Can you use synchromesh in a honda transmission? I always use the honda manual transmission fluid and with working in an oil change shop I was under the impression that synchromesh was for gm transfer cases and some gm manual transmissions. I would try out the honda manual transmission fluid and see if it helps
kevinm1981
31
Aug 2, 2011 10:02 AM
Fat Chick Magnet
Dec 5, 2007 10:59 AM
TypeGSR196
Jun 7, 2006 05:03 AM
RiCE On IcE 2
Jul 26, 2004 04:32 PM
chuteBOXE
Apr 13, 2003 02:34 PM
