3500 rev limited b16
I bought a b16 swap to put in my 90 crx and it is finally in. the car ran great for a while then for some reason the car didnt want to rev above the rev limited 3500. i looked on the ecu and there are 2 codes. one is the idle air control valve and the other is the crank angle sensor. i attempted to fix the crank angle sensor by changing the distributor but that did nothing and from what i have read the idle air control valve wouldnt do that. i also saw someone say the primary o2 sensor might do that. can somebody please help this thing is driving me crazy!
well i called my mechanic today and he said he went to check the timing and cant find the timing marks. so will somebody please tell me where the timing marks are so i can call him tomorrow and get this takin care of.
hey man good work posting it up on HT
if your mechanic cant find the timing marks find a new mechanic
they are located on the two cams, each one has a dot on them. you need to line those up
Derrick_12341
Aug 10, 2018 07:03 AM
dean2
Dec 27, 2006 11:21 AM
wickedEFguy
Oct 6, 2004 02:46 PM
