2003 Honda Element blower motor?
Old Jan 13, 2008 | 04:06 PM
budomove's Avatar
Default 2003 Honda Element blower motor?
I was clearing the maintainance required light on a honda element. I started the car, and there was no air blowing. I checked the heater motor fuse under the hood, and it seemed fine. The air doesnt blow on any setting, Could I have caused damage when I reset the maint reqd light? I ordered a blower motor in case thats the problem, what do you guys think?
Thanks in advance!
frank
Modified by budomove at 7:25 PM 1/14/2008
Old Jan 14, 2008 | 07:49 AM
budomove's Avatar
Default Re: 2003 Honda Element blower motor? (budomove)
pre-lunch bump
Old Jan 14, 2008 | 12:54 PM
budomove's Avatar
bump
Old Jan 14, 2008 | 06:24 PM
budomove's Avatar
bump
Old Jan 14, 2008 | 09:14 PM
budomove's Avatar
anybody?
Old Jan 15, 2008 | 06:03 AM
budomove's Avatar
Old Jan 15, 2008 | 06:39 PM
b20x's Avatar
Heater Blower Motor Gets
Hot or Blows a Fuse
NOTE: This article applies to ’90–04 Accords,
’92–04 Civics, ’97–04 CR-Vs, ’03 Elements,
’00–04 Insights, ’95–04 Odysseys,
’96–02 Passports, ’03–04 Pilots, ’97–01 Preludes,
and ’00–04 S2000s.
A blocked cooling hose for the heater blower
motor can cause the motor to overheat, draw
more current, blow a fuse, or even melt its plastic
impeller. Before you order a replacement blower
motor, make sure the cooling hose isn’t blocked.
On some models, you’ll find the cooling hose
molded into the blower motor housing; on other
models, it’s a separate piece. Check the S/M for
the vehicle you’re working on to determine the
actual location of the cooling hose.
Old Jan 16, 2008 | 06:31 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: 2003 Honda Element blower motor? (b20x)
I too own an Element, and there's nothing that could have been damaged by simply resetting the maintanance light.
Did you happen to replace the A/C filters prior to resetting that light?
Have the a/c filters been replaced recently or at all?
I've reset my light numerous times thrugh our 40K miles on the car, with no adverse effects on anything.
Old Jan 16, 2008 | 06:47 AM
budomove's Avatar
Default Re: 2003 Honda Element blower motor? (B18C5-EH2)
I did replace the cabin pollen filters once. Now has 110k, and I think I changed them once, or maybe twice. I will check, but I doubt they could be so clogged that they burned out the motor. Thanks for the insight!
Frank
Old Jan 16, 2008 | 07:11 AM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by budomove &raquo;</TD></TR><TR><TD CLASS="quote">I did replace the cabin pollen filters once. Now has 110k, and I think I changed them once, or maybe twice. I will check, but I doubt they could be so clogged that they burned out the motor. Thanks for the insight!
Frank</TD></TR></TABLE>
Well I didn't mean that if you'd never changed them it clog so badly that the motor would burn out.
What I was wondering is that if part of you clearing that light was actually doing a service that entailed changing the cabin filter that perhaps en error occured in the process of changing the filter, thus causing directly or indirectly the blower motor to cease functioning.
I understand that nornally there isn't really a correlation with the blower itself and the filter install-wise, but if it got stuck in their and it hung up in there, etc. etc.
Old Jan 16, 2008 | 07:25 AM
budomove's Avatar
I will check, but the filters are downstream of the blower, and I dont see that as much of a potentiality, but will check nontheless.
Anyone else have any idea?
Old Jan 16, 2008 | 07:53 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Really I think you've got yourself a shitty coincidence.
I can look up the blower motor flowchart when I get back from lunch if you'd like.
Old Jan 16, 2008 | 07:54 AM
budomove's Avatar
That'd be great, but no worries if you don't feel like it.
Old Jan 17, 2008 | 07:00 AM
budomove's Avatar
bump
mkfrl
Nov 14, 2018 04:45 PM
Gofmf
Oct 25, 2008 02:41 AM
rpm1892
Honda Civic (2001 - 2005)
Jul 7, 2008 06:00 PM
