2000 Prelude Different Grooved Pulleys
Old May 3, 2016 | 04:00 PM
BrandonSpringle's Avatar
Default 2000 Prelude Different Grooved Pulleys
Hello everyone. So a couple months back I bought a 2000 prelude that had a H23 swapped into it. The Ac belt used to squeal but for not even for a half second when its first started, but now it's starting to squeal much longer. So I went ahead and bought it a new belt but before I went to put it on I noticed that the belt that was on it didn't fit the grooves on the pulley fully. After long examination I come to find out the crank is 5 groove pulley but the Ac and Alternator is 6 groove pulley. So I'm kinda at a stand still on what I should do. I had a quick idea to change the Ac and alternator pulleys from 6 groove to 5 groove but I don't know how difficult that'll be. If anyone has a solution to my problem. It'll be greatly appreciated. Thanks.
Old May 3, 2016 | 08:49 PM
vtechsjc's Avatar
Default Re: 2000 Prelude Different Grooved Pulleys
I would just get the correct crank pulley and install it if it was mine. The a/c pulley is more work than you want to do. the crank is way easier.
Old May 3, 2016 | 10:20 PM
Bently_Coop's Avatar
Steve at Heart
Get a narrower belt with a equal length.
Old May 4, 2016 | 05:56 AM
fcm's Avatar
fcm
Old Fart
A 6 groove A/C pulley and a 5 groove crank pulley/belt will not hurt anything as long as the 5 groove belt lines up square with 5 of the groves in the 6 groove pulley, I have done this many times. 94
Old May 5, 2016 | 01:00 AM
Yes I figured running a 5 groove belt on a 6 groove pulley won't effect anything because that's what I'm currently doing. But the problem is that is squeals. And the squealing is getting worse. So you think a new 5 groove belt to replace the one on it now ? And would Advance Auto carry the 6 Groove Crank Pulley ?
Old May 5, 2016 | 07:07 AM
fcm's Avatar
fcm
Old Fart
Squealing is a symptom of a worn and/or loose belt, not sure if Advance Auto would carry one, but it would be an unnecessary expense. 94
zcmotor
Oct 1, 2013 08:15 PM
V8wannabe
May 6, 2010 12:56 PM
civiccoupe94
May 1, 2005 10:37 AM
sbITR1044
Jul 21, 2003 05:41 AM
