1992 GSR lights help
Old Apr 12, 2011 | 05:49 PM
sirtef9's Avatar
Default 1992 GSR electrical help
Swapped in the b17, had a lsvtec everything was fine.
Now, the fan has constant power, only works if you ground off one side at the connector. If I jump the switch on the thermo stat nothing happens.
My running lights instantly pop a fuse when turned on. Took out front bulbs but guess its in my wiring.
Where should I start with either issue? Relay? main ground?
Thanks in advance guys!
Old Apr 13, 2011 | 06:20 AM
fcm's Avatar
fcm
Old Fart
Default Re: 1992 GSR lights help
The 92 Integra rad fan power is constant, fuse 12-15A, [hot at all times] in under dash fuse box, the rad fan relay supplies the rad fan with a ground, the relay is controled by the ECT switch that supplies the rad fan relay with a ground, [yellow/green lead].
That is where I would start, [rad fan relay] make sure wiring is correct..
Black- ground
Blue- ground output to rad fan
Yellow/green- ground input from ECT switch, [when engine coolent is 192 degrees F]
Black/yellow- 12V input, fuse 21-15A, [hot at all times] in under dash fuse box.
Make sure you are not confusing ECT switch, [yellow/green and black leads] with the ECT sending unit, [ yellow/green and grounded through sensor].
Sorry I am not sure where the switch and sending unit are on a B17.
For the lights it must be a wiring issue, if you have an aftermarket HU in the dash, pull it and check the red/black lead, [illumination] in stock radio harness, make sure it is not shorting to ground. 94
Old Apr 13, 2011 | 06:28 PM
sirtef9's Avatar
Awesome info thanks, Is the main relay for the fan on the passenger side radiator support?
Old Apr 13, 2011 | 08:29 PM
fcm's Avatar
fcm
Old Fart
Yes, I believe it is right in front of batt. on G2s. 94
Old Apr 13, 2011 | 10:40 PM
sirtef9's Avatar
Thanks bud, working on it tomorrow on my day off, I'll keep posted on both issues
Old Apr 14, 2011 | 09:48 AM
sirtef9's Avatar
Black- ground
Your awesome! Pulled the stereo out and that wire was exposed, taped it up and no more blown fuse, thanks alot! Is that just for the illumination on the stock stereo?
Working on fan now
Fradothepotatoe
Aug 4, 2018 06:11 AM
Double Trouble
May 26, 2007 08:40 AM
Linh.
Dec 24, 2005 07:11 AM
4DRmafia
Sep 1, 2004 02:59 PM
Archidictus
Feb 11, 2004 10:57 AM
