'05 TL VSA Sensor Neutral Position Memorization
Old Sep 18, 2010 | 12:54 PM
sache's Avatar
Default '05 TL VSA Sensor Neutral Position Memorization
Ok I am rebuilding an'05 tl and had to remove the VSA modulator control unit. Now with it all connected and brakes bled I am getting the "/!\ " light. I believe I have to do the VSA Sensor Neutral Position Memorization. I have tried to short the 'SCS circuit' using pin #9 but only blew a fuse. I don't know what this circuit is but followed instructions from a guy who did the same on his TSX. Didn't work for my TL. Trying the #1 pin didn't work either. I don't want to try to do any more as I don't know what might else might trip, or burn out. Hate to fry some computer. Any one know what to do??
Old Oct 1, 2010 | 12:16 PM
GhostAccord's Avatar
Default Re: '05 TL VSA Sensor Neutral Position Memorization
Originally Posted by sache
Hi
your message on 08-14-2008 details, I presume, flash codes from the SRS light in the instrument panel, correct. I was able to get these on my TL 2005, (4-1 and 4-2) but these codes do not match any when compared to the DTC codes listed in my Service manual. Are they suppose to. May I ask where you go these codes and are they suitable for my car?
thanks alot
gary
Hey there, I wasn't able to send this via PM becuase your in-box is full or restricted????
The SRS codes that I listed in the thread you mentioned are from Honda/Acura. I'm not 100% if they are current up to and including 2005 model cars or not. I would presume that they are.
I have a few SRS lists that do not include any of the 3-* or 4-* SRS codes. I would assume that would be because those vehicles do not have SRS seat belt tensioner sensors. Does your car have these sensors? If you do I would go based on the codes and check/test your seat belt tensioner. Could be something as simple as it coming unplugged or a cut/corroded wire.
If you do not have the tensioner sensors I would check your SRS codes again. If they keep popping up over again I would suspect your SRS unit.
Reset the DTC/SRS codes and see if they come back first.
2009HondaAccord
Feb 18, 2018 06:41 PM
Steven Cortez
Nov 14, 2016 09:49 PM
krysted9354
May 10, 2009 06:20 AM
madd
Aug 10, 2004 11:35 PM
