02 crv block?
87.0 mm bore and a 99 mm stroke.
9.6:1 CR
4.765:1 final drive
6500 redline
160 hp 162 tq
2354 cc
composite two stage intake manifold
9.6:1 CR
4.765:1 final drive
6500 redline
160 hp 162 tq
2354 cc
the K24 has a 19mm taller deck height compared to the K20s, which would make up for some of the 13mm stroke increase. I could not find the rod length. I don't know if the compression heights are the same. Do you know the K20 rod length?
the place to call that might know would be http://www.kingmotorsports.com , they are supposedly building a 2.4L RSX Type S project car, using the K24 block, so they might be inside the blocks already and have stuff measured out.
no in a new civic hb with the type s head jeeeeeez man were talkin 240 hp and 200 ft lbs
Would take a **** load of work to be reliable enough for a street car.
