'02+ Civic Si Engine/Ecu same as RSX (base)?
Old Nov 18, 2002 | 02:16 PM
23psi4age's Avatar
Default '02+ Civic Si Engine/Ecu same as RSX (base)?
sup tech people, i asked this question in the EG+ forum, but im retarded and forgot about the tech section.
IS the engine or ecu the same in the new Si and RSX (Base), i ask this because Hondata has a new ECU flash for the RSX that makes great power and improvement, but im interested in a new Si and i was wondering if the ECU flash for the RSX would work on the Si, or if a Flahsed RSX ecu would work on an Si. thanks for any input
heres the thread in the EG+ board
https://honda-tech.com/zerothread?id=336940
Old Nov 18, 2002 | 07:40 PM
23psi4age's Avatar
Default Re: '02+ Civic Si Engine/Ecu same as RSX (base)? (23psi4age)
im the numba 2 stunna wha wha wha wha wha wha wha wha
TTT!!!
Old Nov 18, 2002 | 09:19 PM
incubus's Avatar
Default Re: '02+ Civic Si Engine/Ecu same as RSX (23psi4age)
I would assume that they are different, slightly, you could always source a RSX ECU though and use that. I read that article about the hondata ECU too, it was amazing that they got so much power.
Old Nov 18, 2002 | 09:47 PM
T_Rex's Avatar
I know they share the same motor (read it in Car and Driver and Super Street), but I'm not sure about the ECU.
Old Nov 19, 2002 | 03:07 PM
23psi4age's Avatar
Default Re: '02+ Civic Si Engine/Ecu same as RSX (hondanut)
any body else got any comments
SaraGonyea
May 30, 2018 10:21 PM
01_CivicEM2
Honda Civic (2001 - 2005)
Sep 12, 2011 11:23 AM
KidFrost
Feb 15, 2010 10:14 PM
Vtec Myrmidon
Dec 11, 2002 03:08 PM
23psi4age
Nov 18, 2002 01:32 PM
