00 Si Motor , I got Questions???
Old Nov 12, 2002 | 04:07 PM
B20zvtecek's Avatar
Default 00 Si Motor , I got Questions???
is the Crank Flucuation Sensor the same as the Crank Angle Sensor?
On a 00 Si motor where and what does the Evap Purge Solenoid look like??
Thanks Guys in Advance
Old Nov 12, 2002 | 04:32 PM
Kataku2K3's Avatar
Default Re: 00 Si Motor , I got Questions??? (B20zvtecek)
On OBD2 motors in the distributor you still have the same sensors, CKP, CYP, and TDC.... on the oil pump you also have the crankshaft speed fluctuation sensor.. I don't know which one is being refered two as the crank angle but i would think that you are talkin about the crankshaft position sensor in the distributor.. Again don't take my word for it, as i am not sure which one they are talkin about.. Also OBD2 motors have a different type of purge solenoid.... I'm not perfectly sure on the 2000 Si but you can see it ontop of any of the new integra motors just to double check... It's a little black solenoid with a hose running off of it to the intake manifold and to the purge canister..
Old Nov 12, 2002 | 04:33 PM
Kataku2K3's Avatar
Default Re: 00 Si Motor , I got Questions??? (JDMspecEG6)
You should be able to figure it out..... If not then i'll try to find a pic of a 99-00 Si engine bay to show you exactly where it is ... Latez
Old Nov 12, 2002 | 04:41 PM
B20zvtecek's Avatar
i found the CKF sensor , but still and stumped on the Evap purge .
Is it mounted on the fuel rail or is that one other sensor also , oh yeha the one on hte fuel rail has a red hose??
Old Nov 12, 2002 | 04:53 PM
Kataku2K3's Avatar
That may be it, damn it sucks I can't think right now.... It's above the fuel rail right??? does it connect to a plenum off the top of the manifold?? You know what the PCV system is right because I just don't want you to get all confused.. Good Luck
Old Nov 12, 2002 | 05:08 PM
B20zvtecek's Avatar
Thanks man , im almos there , i think i can figure out the rest
chicows18
Jul 19, 2009 06:45 PM
jjmcmana
Nov 1, 2008 09:02 AM
Spence
10
Apr 24, 2006 09:37 PM
bluesi00
Jun 2, 2004 11:35 AM
Nvious R
Oct 28, 2003 06:27 PM
