00' SI CEL
Old Oct 12, 2008 | 06:22 PM
Handyman_1's Avatar
Default 00' SI CEL
I have a 00' SI and my cel came on. I scanned it and it came up with P0301, P0303, and P0300. There is a misfire in cylinders 1 & 3. I know that it does not have anything to do with the ignition. I was thinking maybe it could be a clogged fuel filter or a falty injector. Does anyone have any ideas on what else it could be?
Old Oct 12, 2008 | 06:50 PM
dtapia's Avatar
Default Re: 00' SI CEL (Handyman_1)
but a tight valve will cause a random miss fire code since the air fuel is out of range if you have a live data stream on the scanner see what the map voltage is.
a fuel injector could be also but have not seen a fuel filter cause random miss fire yet.
Old Oct 12, 2008 | 07:34 PM
Handyman_1's Avatar
Default Re: 00' SI CEL (dtapia)
I will check the voltage. Thanks
Old Oct 13, 2008 | 04:38 AM
King V's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Handyman_1 &raquo;</TD></TR><TR><TD CLASS="quote"> I know that it does not have anything to do with the ignition. </TD></TR></TABLE>
Incorrect. If your plugs/wires/cap/rotor(all ignition parts ) are no good, you'll get a misfire. Try changing any one or all of those before you go tearing into the engine for no good reason.
Old Oct 13, 2008 | 07:15 AM
Handyman_1's Avatar
Default Re: 00' SI CEL (King V)
I only said it has nothing to do with the ignition because I already changed the plugs, wires, cap, and rotor.
Old Oct 13, 2008 | 02:49 PM
King V's Avatar
Weak coil or ignitor module
Old Oct 14, 2008 | 10:29 AM
Handyman_1's Avatar
So I checked the injectors and came to the conclusion that they were fine. I decided to do a compression test. In cylinders 2,3, and 4 the compression is 165 PSI. and in cylinder 1 it is only 30 PSI. I was told it could be a worn lob on the cam shaft or a stuck vavle. What do you think?
Old Oct 14, 2008 | 06:01 PM
dtapia's Avatar
i have yet to see a flat cam lobe on a honda but things happen. i would be looking more towards a tear down.
Old Oct 14, 2008 | 07:27 PM
Handyman_1's Avatar
I was thinking more towards the valves rather then the cam lobes. This is hurting my head.
2000-em1
Aug 12, 2012 04:22 PM
OhWUNshlude
Nov 29, 2007 09:37 PM
Excelerate
Sep 29, 2006 01:04 PM
Street Inc
Aug 4, 2006 06:02 PM
gemini05
May 25, 2006 07:41 PM
