00 integra wont start
Old Sep 27, 2009 | 07:03 AM
benjamenenglish's Avatar
Default 00 integra wont start
i pulled apart the dizzy, put it back together and it wont start now im gettin spark fuel and im not 180 out, main relay is good brand new dizzy cuase i thought i broke it, batttery is charged. it cranks really fast... plz help im stuck.
Old Sep 27, 2009 | 08:26 AM
Muckman's Avatar
Moderator in Chief
Default Re: 00 integra wont start
you sure the plugs are on the dist in the correct order?
Old Sep 27, 2009 | 08:55 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^
If you have good spark and fuel it has to be timing, recheck spark plug lead locations. 94
Old Sep 27, 2009 | 11:00 AM
dannydanny's Avatar
New User
have the dizzy mounted loose, have someone crank the engine while you turn the dizzy.. the timing might be just off.
have done that once before and it seemed to be the problem.
Old Sep 27, 2009 | 11:55 AM
did the loose dizzy,
Old Sep 28, 2009 | 03:10 PM
blown motor
zero compression
Old Sep 28, 2009 | 05:11 PM
its got zero compression arcoss the board, whats going on??
Old Sep 29, 2009 | 05:23 AM
fcm's Avatar
fcm
Old Fart
Zero compression???
Are you sure your compression gauge is working, I don't think I have ever seen an engine with zero compression across all cylinders. 94
Old Sep 29, 2009 | 06:42 AM
Muckman's Avatar
Moderator in Chief
check valve lash and tbelt. theres no way every cyl is 0psi even on a blown motor.
Old Sep 29, 2009 | 02:38 PM
guage is fine did it on my civic it was workin. ok ima check valve last and tbelt now
Hondaguy83
Dec 5, 2012 05:21 PM
Ek9_Cuhzz
58
Jan 7, 2011 04:54 AM
94-integra-ls
Sep 26, 2009 01:34 PM
hmtcrxsir
Jul 10, 2007 10:06 AM
FastReligion
May 25, 2006 09:18 PM
