**Girl in need of Help Interga problem**
Old Jul 8, 2003 | 10:57 AM
GurlieChick333's Avatar
Default **Girl in need of Help Interga problem**
Sorry to not have a general question on my topic but i dont know whats wrong with my car and i was wondering if anyone else might have had the same problem.. My car is a 94 LS with 144,xxx mils on it I replaced the tranny last winter and it works great but last week when i cranked my car it started reving up to 3 and then shooting back down to 1 and doing that over and over. when i drove it for a little while it would go away but now its doing it worse.. And now it wont go away when im driving it. It does that when im idling. and now its not wanting to crank up at all. I changed my oil spark plugs and cleaned out my throttle body with cleaner And it still hesitates to crank up I was thinking it might be my gas pump not turning on But they rarely go out?? Any one have any sugestions besides getting a new car... Thanks for all your help!!! ~Jessica~
I also have checked the coolant and its fine..
Old Jul 8, 2003 | 11:11 AM
V-Grip! Teknic73's Avatar
Default Re: **Girl in need of Help Interga problem** (GurlieChick333)
sounds like a vacuum problem
Old Jul 8, 2003 | 11:13 AM
orange.honda's Avatar
do you have an mil. this could help you get into the right mindframe.
Old Jul 8, 2003 | 11:16 AM
Default Re: **Girl in need of Help Interga problem** (orange.honda)
Orange Honda , Not sure i know what your talking about ??
Old Jul 8, 2003 | 11:21 AM
skribblah's Avatar
girlie girl heheh three three three!
the orignal "im a girl help me" type thread...
Old Jul 8, 2003 | 11:23 AM
mil: malfunction indicator light. its a check engine light. if the check engine light is on then it will give you a code. this code will in turn point you in the appropriate direction.
Old Jul 8, 2003 | 11:24 AM
Default Re: **Girl in need of Help Interga problem** (skribblah)
Yes i know that im a girl!! Good looking out!! But seriously i just want to know if anyone has had this prob before and might want to help out.... That is what this fourm is for right?? At least im here trying to figure out whats wrong with it...
Old Jul 8, 2003 | 11:26 AM
so yes or no?
Old Jul 8, 2003 | 11:27 AM
Yea thats the weird thing it's not throwing any codes.. No check engine lights nothing.. Just wont crank and if it does it revs up to like 3.5 and goes straight down and dies.. Then i have to sit and crank it again and feather the gas to keep it cranked...
Scott_Tucker's Avatar
A faulty idle air control valve is a common cause of this.
Old Jul 8, 2003 | 11:53 AM
Default Re: (AutoEng2002Si)
anyone have anymore sugestions?? I appreciate all you guys help!!
Old Jul 8, 2003 | 12:05 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GurlieChick333 &raquo;</TD></TR><TR><TD CLASS="quote">Yea thats the weird thing it's not throwing any codes.. No check engine lights nothing.. Just wont crank and if it does it revs up to like 3.5 and goes straight down and dies.. Then i have to sit and crank it again and feather the gas to keep it cranked...</TD></TR></TABLE>
Have you performed any engine mods recently? or let someone fiddle around with your engine or ecu at all ?
Have you checked your coolant level?
Sometimes if your car is way low on coolant/water the idle surges exactly like what your is doing.
Old Jul 8, 2003 | 12:13 PM
HotRodDelSol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoEng2002Si &raquo;</TD></TR><TR><TD CLASS="quote">A faulty idle air control valve is a common cause of this.</TD></TR></TABLE>
probably what it is
always happy to help another girl out
Old Jul 8, 2003 | 12:21 PM
Default Re: (HotRodDelSol)
Thanks soo much guys i appreciate all the help!!
Old Jul 8, 2003 | 12:30 PM
Default Re: **Girl in need of Help Interga problem** (Katman)
(Katman)...No mods recently i just have an intake and an exhaust but they were put on when my tranny was replaced last winter.. And no ones has been messing with the ecu either.. Just started doing this on its own... I guess its getting old and things are breaking i just wish i knew what was broken????? Frustrated.........
Old Jul 8, 2003 | 12:40 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GurlieChick333 &raquo;</TD></TR><TR><TD CLASS="quote">(Katman)...No mods recently i just have an intake and an exhaust but they were put on when my tranny was replaced last winter.. And no ones has been messing with the ecu either.. Just started doing this on its own... I guess its getting old and things are breaking i just wish i knew what was broken????? Frustrated.........</TD></TR></TABLE>
Again, check the coolant level.
Remove the rad cap and see if the coolant is topped off, if it looks dry in there, add some water till its topped off.
If that's not the issue, of course, it could be a vacuum line issue. Either a vacuum line came off (somewhere on your intake manifold) or there's a small hole punctured in a vacuum line.
Old Jul 8, 2003 | 12:54 PM
Coolant level is fine right up to the top!! But keep the sugestions coming guys its bound to be something.... Thanks for the much needed imput...
Old Jul 8, 2003 | 01:52 PM
skribblah's Avatar
hey "~jessica~" your *** got a repily on the first post. you have a vacume problem. take off your skirt and get it fixed.
Old Jul 8, 2003 | 02:15 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skribblah &raquo;</TD></TR><TR><TD CLASS="quote">hey "~jessica~" your *** got a repily on the first post. you have a vacume problem. take off your skirt and get it fixed.</TD></TR></TABLE>
Wow, that's like saying you have an "engine problem". Maybe she wanted a better or more detailed guess so she wouldn't waste her time with things that were fine?
She obviously knows what she's talking about, so get off your ******* high horse. Just because she's a girl doesn't mean she doesn't know or do anything right. Just reading her posts tell you that she's at least car competent.
Old Jul 8, 2003 | 02:16 PM
whatVTEC's Avatar
IAC...idle air control
Old Jul 8, 2003 | 02:20 PM
DeDonDeRosa's Avatar
Default Re: **Girl in need of Help Interga problem** (whatVTEC)
yep faulty IAC valve have seen this prob before
Old Jul 8, 2003 | 02:59 PM
poison's Avatar
You, dude, are a dumbass.
Things like that aren't welcome here.
As for the problem:
Usually the cause of this is a bad or dirty IACV (idle air control valve).
Get some carb or brake cleaner, take off the IACV (which is located on the back of your intake manifold), and spray the brake/carb cleaner on it to clean all the **** on there.
Once you have done that, put the IACV back on, and start up the car.
Old Jul 8, 2003 | 04:34 PM
(Skribblah)-----&gt; I'm on this fourm trying to find out whats wrong with my car.... If i was just some dumb A$$ Girl i wouldn't be on here in the first place let alone be trying to fix my problem.. Its guys like you who make a bad name for everyone else... Yes some girls are car competent and compared to some STUPID things i have read on here from guys i dont think me asking for some little help with a problem that could be any of 50 different things is asking to much... I dont see Why i just cant get help on here like anyone else... I shouldn't have to be defending the fact that im a girl!!!!!!!!!!!
Thank you to everyone else who is trying to help it's very much appreciated!!!
Old Jul 8, 2003 | 04:51 PM
poison's Avatar
You'll get it fixed. Erratic idles are a bitch to find. But you'll get it.
eqmassa
Jan 30, 2012 06:14 AM
skata89
Jan 24, 2011 08:23 PM
3k9civic
Sep 15, 2006 08:45 PM
Sic_DA_Nine
Feb 3, 2006 11:07 AM
ActiveAero
Nov 25, 2001 08:40 AM
