"shave the block"
Old Apr 24, 2002 | 12:11 AM
b20eg6's Avatar
Default "shave the block"
To "shave the block" to a certain MM. Could someone explain the process/tools and work involved to complete the process?
Old Apr 24, 2002 | 02:25 AM
OneThirtyEight's Avatar
Default Re: "shave the block" (b20eg6)
I think you are talking about shaving the head, commonly known as "milling" it. It makes the combustion chambers that much smaller, resulting in a higher compression level. You need some major machenery to do this.
[Modified by 97blackteg, 6:26 AM 4/24/2002]
Old Apr 24, 2002 | 02:29 AM
rainforest's Avatar
decking the block makes sure taht the block is 100% square. its so you know your mating surface with the head is flat and wont throw a headgasket.
Old Apr 24, 2002 | 06:37 AM
earl's Avatar
Default Re: "shave the block" (rainforest)
Deck as little as possible. Anymore than a few thousandths is too much.
eg:R
Apr 19, 2014 08:56 AM
demian22
Feb 28, 2008 10:34 AM
10SecDSM
Sep 15, 2006 08:11 AM
Lewcis
Jul 29, 2004 09:19 PM
