Progress Technology CS2 Problem
I have it threaded a little above halfway maybe half way up the sleeve and i cant go higher wtf do i need a spring compressor ???
it sits way too low
No just moar powar
Did you loosen the allen bolt that tightens the collar? Are you using the coilover wrench correctly. With a little elbow grease you should have no problem moving the collar up even with the coilovers on the car.
It was hard as hell even when I installed them
Take off the top nut, jack up the chassis, raise the perch, carefully lower the chassis, tighten nut. That's as high as you'll get without any extra preload.
E. Honda
21
Jul 18, 2002 09:36 AM
