Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Problem with GC coilover....
Old Mar 28, 2003 | 10:05 AM
chrisb's Avatar
Default Problem with GC coilover....
Has anyone experienced this problem with their GC coilovers? You tighten the allen wrench screw as tight as you can yet the adjustable spring perch still easily rotates on the collar? On three of mine I had to crank the hell out of the screw and it seems to just barely be grabbing the collar at all. But on the fourth one no amount of tightening will make the spring perch lock in place. Is their any fix or do I need a new part?
Old Mar 28, 2003 | 10:20 AM
PhucNguyen57's Avatar
Default Re: Problem with GC coilover.... (chrisb)
https://honda-tech.com/zerothread?id=456505
Old Mar 28, 2003 | 10:21 AM
Track rat's Avatar
Make sure that it is not just the threaded sleeve moving around the shock body, and the collar is locked and moving with it; this is normal. If your collar is turning around the threaded sleeve with the set screws locked, then you should contact GC!
Al
THMotorsports
Suspension & Brakes
11
Dec 12, 2005 08:47 PM
ej2civic
Suspension & Brakes
Apr 28, 2005 02:58 AM
civic702
Suspension & Brakes
Jan 18, 2005 04:07 PM
