Suspension & Brakes Theory, alignment, spring rates....
poly bushing replacement problem
Old Nov 3, 2014 | 05:23 PM
dc4teg95's Avatar
Default poly bushing replacement problem
So my bushings in my skunk2 rear lcas are completely destroyed. I got new replacements for the whole arm for both sides to switch the bushings skunk2 new design but i got a problem. Some of the bolts snapped and now i have to cut the bolt and sleeve to fully remove the arms. Problem is s2 doesnt sell replacement sleeves for the bushings. I have had a old set of ES front upper bushings that has new sleeves and they fit perfect except they are a hair too small O.D. causing them to spin very easily inside the bushing. Would it be ok/safe to use these sleeves still?
Old Nov 4, 2014 | 03:08 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: poly bushing replacement problem
The sleeves need to rotate inside the joint...but there shouldn't be any space between. Measure what's left of the old sleeves and see how far away you are with the new ones. Ideally, you'd want a light press fit into the poly bushing...but one that still allows the sleeve the float.
Old Nov 4, 2014 | 05:24 PM
dc4teg95's Avatar
The bushing measures I.D. (.8) and the new es sleeve measures O.D. just under the bushings I.D.
The sleeve slips right into the bushing.
Old Nov 5, 2014 | 03:55 AM
B serious's Avatar
Then its no good. You're going to have slop there and tear the bushing up faster than expected.
Old Nov 5, 2014 | 08:21 AM
B serious's Avatar
You can buy DOM tube. 13/16 OD. 3/16 wall thickness (.437 ID). That should do the trick. You'll have to cut it to size.
You can buy 3/8 ID tube also...and just drill the center with a 10mm drill bit to fit the M10 bolt.
Old Nov 5, 2014 | 03:43 PM
dc4teg95's Avatar
That's what I was thinking but wasn't sure. Where could I get Dom tubing from?
Old Nov 5, 2014 | 06:00 PM
B serious's Avatar
McMaster carr, hardware store maybe. Etc.
Don't buy pipe or something weak ***. DOM tube is made from cold rolled 1020/1026 steel.
Old Nov 7, 2014 | 01:31 PM
$MIKE$'s Avatar
Might just wanna get new bushings from s2 or hardrace.
Old Nov 22, 2014 | 06:19 AM
dc4teg95's Avatar
Update. I called skunk2 and they are sending me a replacement metal sleeve
Mike239
Suspension & Brakes
Mar 11, 2011 10:26 AM
1.5Slowmatic
Suspension & Brakes
Nov 19, 2008 08:44 PM
BRYEM2
Honda Civic (2001 - 2005)
Sep 27, 2008 03:47 PM
CerealWars
Suspension & Brakes
Sep 28, 2007 07:50 PM
