No, you DO NOT need camber kits!!!!!!!!
#701
Re: No, you DO NOT need camber kits!!!!!!!!
Ok, so I went to another place and they quoted me $60 for an alignment. They also did recommend a full camber kit as well. What they told me was that without it, all they will be able to do is adjust the toe and that's all. And even with that adjustment, my tires will wear out fast.. is that true?
Should I go ahead and get the camber kit or just pay them $60 to align/toe adjust..?
Camber does wear tires but it does it slowly. Toe is the true tire killer.
I've been running -2* all around for almost 2 years and my tires are still wearing perfectly.
The dude at firestone is surprised every time I come in. lol
#702
it's just an attempt to make money, that's all.
#704
longest project ever
Location: on the south side of dixie, 1986 Accord Hatch
This is why I love having a third generation accord, swap in 2nd gen lude upper arms with a few washers as spacers, and instant factory camber kit, plus the ball joint can be replaced without trashing the entire arm, they also make a kit for the back now where you can replace just the ball joint, instead of trashing everything
#705
You don't *need* it, but I would throw a few washers on the rear UCA's.
I had -3.5* in the rear before 2 thin washers on each bolt. Now it's about -2*
I was at -3.5* for a year and still got perfect tire wear.
#706
Alright, I'll get at that when I get a chance. I bought the lifetime alignment thing so I can always go and have them check the toe/camber readings.
#709
CAMBER IS NOT SUPPOSE TO BE A TIRE WEARING ANGLE, TOE IS. AND YES TIRE ROTATIONS ARE A BIG HELPER WITH TIRE WEAR. BUT WHEN RUNNING LOW PROFILE TIRES LIKE A 45 OR 50 SERIES, CAMBER DOES IN FACT PLAY A PART IN TIRE WEAR. I BEEN DOING ALIGNMENTS FOR ABOUT 7 YEARS AND I DISAGREE WITH THIS POST OTHER THAN KEEP ROTATING TIRES ATLEAST TWICE A YEAR AND CHECK YOUR ALIGNMENT EVERY 6MONTHS/6K MILES. SURE NEGATIVE CAMBER IS GOOD FOR THE TRACK. BUT IF IT WAS MEANT TO BE DAILY DRIVEN ITS A WHOLE DIFFERENT STORY.
#711
this is like the idiot who was going to do my alignment and insisted my car had a "standard" McPherson strut suspension" , when it has a double wishbone
#714
My local firestone guy told me just 2 weeks ago when i had my lifetime alignment done that as long as i kept my tires rotated and toe in adjustment i wasn't gonna have to worry about. Besides i have had some neg camber for some time now and so far no uneven wear that i can tell.
#715
three posts and are arguing with people who have been running this camber for a long time and know how it affects tire wear? AND IN ALL CAPS
#716
#1 Super Guy
This would only be true if you drove in perfectly straight lines. The more aggressive you like to corner, the more negative camber WILL be necessary to maintain even tire wear. Aggressive cornering moves your tire wear toward the outer edges of the tires. The more you enjoy lateral G's and grippy tires, the more negative camber you need.
You have to remember our cars weren't originally marketed as sports cars. When you drive them like sports cars, some things need to be changed.
#717
Most enthusiasts prefer more neutral rear camber (relative to the front) for better rotation/driving feel. That's going to be true of any platform with front weight bias.
#720
#721
I put adjustable upper links in the rear. My tires are wearing perfectly now as opposed to before when they were wearing like ***. There is noticeable reduction in road noise, tire wear, improved gas mileage, my temp gauge runs about 1/8 inch lower than it did before and the car feels like it gained about 20 HP. My car doesn't grab the ruts in the road anymore. My tires were wearing on the inside edge with pretty severe cupping and noise that was driving me nuts. My steering wheel and the whole car shook when I hit 80 mph. Those problems are gone now. The noise and vibration are gone. It is awesome to see the tires are wearing evenly all the way across. Yes I did need a camber kit, but then I drive 170 miles per day and tire wear, mpg, handling and performance is critical for me. Well worth the ~$105. Can't wait to do the front.
I had a 4 wheel alignment before installing the camber kit and it didn't help.
#722
#1 Super Guy
The fact that they never calibrate their alignment machines sure does. Ask any tire shop that doesn't do alignments what they think of the tire shops that do. The only tire place I've had decent luck with alignments would be Sears. But even then they are not 100%. I've since taken to doing my own string alignments and I get all 4 of my vehicles arrow straight every time.
#723
#724
Thanks so much to all that contributed solid info on this thread. Just finished (finally) reading it all and have learned a lot. Gave me what I needed, and basis for more intelligent searches about related subjects.
Thanks again for sharing true knowledge and personal experience.
Keith LeBlanc
Keith LeBlanc
#725
yes you do need a camber kit when lowering suspention too much negative camber will kill your tire the toe need to be off extreme to cause tire wear the worst one is camber i dont know where you got your info but camber is really important you must be owning a tire you and you want to sell tire
camber kit are mandatory when lowering suspention
