Suspension & Brakes Theory, alignment, spring rates....
master cylinder rebuild kit for 15/16" eg6
Old 05-23-2015, 03:16 AM
DiSCLAiMER's Avatar
Default master cylinder rebuild kit for 15/16" eg6
where to buy a nissin 15/16" brake master cylinder rebuild kit for a eg6?
Thanks!
Old 05-23-2015, 03:21 PM
Steve at Heart
Bently_Coop's Avatar
Default Re: master cylinder rebuild kit for 15/16" eg6
Just buy a new master cylinder from Rock Auto. They are not that expensive.
Old 05-23-2015, 11:35 PM
DiSCLAiMER's Avatar
thanks, you are right!
any hint witch would be best? my car has abs.
https://www.rockauto.com/catalog/raf...&parttype=1836
Old 05-24-2015, 01:43 PM
Steve at Heart
I picked up a Raybestos for my 89 civic. It is a 15/16" and from a 90-91 EX sedan direct bolt on. Raybesto IMO is good quality. I can't tell which are ABS compatible either.
Not sure if you have read the sticky but here is some good information regarding choosing the correct size.
Originally Posted by BrakeExpert
Master Cylinder relative to the Caliper
When you go to bigger caliper than use a larger piston, you are pushing more fluid through the brake lines. Therefore, you should want a larger master cylinder to push this more fluid.
General rule is…with your stock Civic DX, with the stock front calipers, keep your 13/16” MC. Any bigger and your pedal will be too stiff.
With EX/Si calipers, use a 7/8” MC from a 96-00 EX or 99-00 Si because of the more fluid going to a larger piston.
With ITR/Legend/Vigor/Accord V6 or Integra DA or DC calipers, use a 15/16” MC from a 98-01 Integra LS to accommodate for the even more fluid. Any smaller of a MC will cause the pedal swing to be too long.
With NSX or Legend GS calipers that have two pistons, or an aftermarket caliper with multiple pistons, you’ll want a 1” MC because of even more fluid required to push all the pistons. Get the 1” MC from a 98-01 Integra GSR or ITR MC as it bolts onto the EK brake booster.
When changing out a master cylinder, be sure to 'bench bleed' it first. This involves having fluid in the resovoir and pumping it unconnected to allow fluid to fill the internals. If you don't do this, you can still bleed the car, but you may be at it all day, since air pockets may stick in there. Research bench bleeding before you attempt this on your own.
A bigger caliper usually has a bigger bracket, thus holds a bigger surface area pad. This is generally better, and that’s why on a Civic, you swap on an Integra caliper, because the piston is bigger (more fluid, that doesn’t help) but the pad is bigger, and the piston disperses its energy over more area because of a larger contact surface with the shim.
Here is another thread with decent information as well.
https://honda-tech.com/honda-civic-d...civics-364783/
Old 05-25-2015, 12:16 PM
DiSCLAiMER's Avatar
Thanks, i'm only replacing the one it comes oem (15/16"), not trying to upgrade.
hulsey
09-06-2012 07:11 AM
9112
11-30-2007 07:29 AM
adrian1281
08-23-2003 09:43 PM
miataguy
07-08-2003 09:00 PM
jdmcivicferio
04-02-2003 03:49 PM
Quick Reply: master cylinder rebuild kit for 15/16" eg6
