Suspension & Brakes Theory, alignment, spring rates....
Gsr Calipers on Stock civic vx brakes
Old 11-22-2009, 05:38 PM
LoneAutosport's Avatar
Default Gsr Calipers on Stock civic vx brakes
Would gsr calipers bolt right up to my stock vx brakes. Also if i do put the gsr calipers will my 13" lenso fit w/o any grinding down on parts?
Old 11-23-2009, 12:46 AM
tazeat's Avatar
Default Re: Gsr Calipers on Stock civic vx brakes
Have you read the brake FAQ on here? (honest question)
Old 11-25-2009, 12:27 PM
roastbeefrichie's Avatar
unfortunately, the integra calipers won't bolt up to your civic VX knuckles. fastbrakes.com sells brackets and bigger rotors in order to use integra calipers, but 15" wheels are required. your 13" lenso fits will limit your choices for brake upgrdes.
* have you considered staying with your civic calipers? get blank rotors, good set of pads, s/s lines with fresh brake fluid
Old 11-25-2009, 07:42 PM
Yea i've been considering upgrading the pad, rotors, and lines. But i thought if the gsr calipers worked it'd be a nice little upgrade. Thanks
Old 11-25-2009, 08:19 PM
dim-sum's Avatar
i dont think theres nothing you can do if you want to run 13" slicks....
ive seen 4 piston calipers from kvr that were for dx application using the original 9" brakes
shwepes
Suspension & Brakes
01-23-2016 06:17 PM
mdixonjam
04-17-2005 08:11 AM
strepto
08-06-2003 08:20 AM
TurboBumblBee
20
01-30-2002 05:06 AM
Quick Reply: Gsr Calipers on Stock civic vx brakes
