Suspension & Brakes Theory, alignment, spring rates....
ground control fitting question?
Old Sep 20, 2005 | 01:07 PM
CivicHP's Avatar
Default ground control fitting question?
here is may question i have a 93 civic and i could get some used ground control coils 92-00 limited edition that where previously installed on stock shocks. i want to put theme on tokico hp will that be possible it the same installation and fitting or different?
Old Sep 20, 2005 | 02:13 PM
Tyson's Avatar
Default Re: ground control fitting question? (CivicHP)
it should be fine. the kit should be the same.
id be wary about using tokico blues tho.
Old Sep 20, 2005 | 07:49 PM
CivicHP's Avatar
why is that? i never heard anything bad about this combo.
Old Sep 21, 2005 | 10:05 AM
Tyson's Avatar
Default Re: (CivicHP)
i dont have much faith in tokico blues. im a fan of their illuminas, but from what i understand their blues are being produced in their chinese plant and im hearing lots of reports on shoddy quality. blues really arent meant to be more than fresh stock shocks, so thats why i wouldnt pair them with ground controls.
Old Sep 22, 2005 | 07:09 AM
CivicHP's Avatar
so wich shock you recommend me i will use it mostley for street and lower maybe 2" max and i don't want any adjustable one's cause i don't think i need those.
Old Sep 22, 2005 | 07:32 AM
Jamez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicHP &raquo;</TD></TR><TR><TD CLASS="quote">so wich shock you recommend me i will use it mostley for street and lower maybe 2" max and i don't want any adjustable one's cause i don't think i need those.</TD></TR></TABLE>
Believe me, you do. I said the same thing when I bought Blues for the front, thinking non-adjustables are just as capable as adjustables but without the fine tuning. WRONG. I've said this in another thread but I'll say it again ; there are no real performance non-adjustables available (at a reasonable price, Bilstein doesn't count).
Go with KYB AGX, Tokico Illumina or better yet Koni Yellow. Hold off your suspension projects until next spring if you have to, you'll be thanking yourself. I see your from Montreal, just imagine what conditions the roads will be in next spring, do you really want to be tackling those potholes with an inferior shock?
Old Sep 22, 2005 | 09:45 AM
Tyson's Avatar
Default Re: (Jamez)
i think illuminas are a good value if you find them at the chepaer than retail costs. ebay is a good palce to start. shox.com has the best retail deals, good service.
Old Sep 27, 2005 | 10:27 AM
Groundcontrolstore.com's Avatar
Default Re: (Tyson)
be sure whoever you are buying your used GC's from includes the urethane O rings because you will need those to adapt the tube to the shock
tduzzle
Suspension & Brakes
Feb 19, 2008 05:24 PM
al4t1gbundy
Honda S2000
10
Aug 29, 2007 11:58 AM
mister_ej1
32
Mar 22, 2007 10:53 PM
tougeDC4
Suspension & Brakes
Dec 29, 2006 10:39 PM
mebriwhou
Apr 3, 2002 07:23 PM
