CLICK HERE all of you curious about suspension setups and their costs/reliability.
#301
Ek Forever y0!
Re: CLICK HERE all of you curious about suspension setups and their costs/reliability
Ok, THMotorsports stated on the first page of their thread selling the Koni/GC combo that they suggest the following spring rates:
Street Use Only: 290/350Lbs
Street/auto-x: 350/380Lbs
Street/Road Course: 380/450Lbs
I then asked if that was F/R or R/F because most posts suggest a higher spring rate in the front due the the added weight of the motor. TH however says this:
Its F/R. Since its a FF car, they are prone to understeer. Having a higher spring rate in the rear helps to car to rotate and counter-act the understeer offering a more neutral feel.
What I am asking is if you could comment on this - thanks!
There are several ways to approach promoting oversteer for a track car. One is by having much stiffer rear rates and suitable swaybars or sometimes no swaybars. (Swaybars become less effective the higher the spring rates.)
From my understanding, I'll use Japan as an example of a place where I've heard they do this: they tend to do the reverse, Stiffer rates up front, with big swaybars in the rear to give the car a more balanced feel without having too much oversteer.
Under-steer is sometimes a little easier to control if you know what you're doing, it's all based on driver preference.
For a daily driver/dual duty car it's usually best to be conservative with the rear rate as the rear rate is far more indicative of the ride quality than the front rate.
I.E., while I know 550F/700R would be superior for my car for road racing/autocross, I drive my car daily and don't want to have a herniated disk. So the compromise for my next suspension setup is running a 550F/450R setup with a 24mm rear swaybar to keep the car pretty neutral and tolerable on the street and highway.
#304
Ek Forever y0!
Sloppy? What are your alignment specs? Roll center adjusters would help, especially at your ride height.
#305
Ek Forever y0!
Get the toe set in, in the rear ~.03-.05 and out in the front ~.03
SUPER close to zero but just a hair in in the rear and a hair out in the front. It will lighten up the steering and promote great stability on the highway while maintaining good turn in qualities.
#306
What's the best spring rates for koni str.t / GC for 96 accord 4dr lx? Since I heard str.t might not be able to handle higher rates will 350F-300R do or ??
#308
Thanks to this thread and Libertariat (advice/knowledge)
I picked up my starter set, progress cs-II 350f/250f (will eventually go higher later,later)
thanks again
PS yes I've been here long and yes that's my that post count. lol
thanks again
#309
Progress CS-II--2 BIG THUMBS UP!! i love them
(350F/250R--Recommended preload install, w/12" front 12.5" rear measurements)
Absolutely love the height, its perfect! Rides and handles like a dream
Don't mind the 13's they're my everyday wheels/tires
thanks again suspension gurus!
#312
Hey guys im wondering what would be a great reliable suspension set up on my 94 civic coupe. I have some xxr 002 0 offset wheels i got the rear skunk 2 camber on and my suspension is stock as of now except for some reason i have only one coilover and the rear passenger side? Which the rear passenger side is higher and my wheels rub on the rear driver side only.. So im looking for some coilovers in the 600-800 dollar range. Im also waiting on my skunk 2 front camber kit and im not wanting the hella hellaflush look but the wheels stick out so much it looks beyond riced out unless i tuck em a bit. How much should i tuck them so it wont rub plus having my ride low?
#313
I do need ball joints as well. lol
That car is going to look goofy.
What is the specs on the wheels? Width, tire size?
#315
well i seen some pull em off without going so negative with 0 offset wheels there 205/45r16 8 width
#318
I have 2002 Accord LX 4 cylinder w/ stock wheels. Its a DD do everything family car. Setup will consist of Eibach Pro kit shocks and Swift Sport Springs (252/168 w/ 1.2" drop front and back).
Plan on having alignment done roughly 2 weeks after install. Should I stick with OEM alignment?
Daniel
Daniel
#319
Ek Forever y0!
Daniel
Daniel
#321
great thread !! wish i did more homework before my purchase i ride w f&f type I but im not 100 satisfied.. my question is .. i got a em1 00 and it has a sound system.. one of my close friends advice becaue of the speakers my car is not driving to expectations. im really interested in koni /gc but he said because of the extra weight i will be getting same result .. by reading this thread i came to conclusion w a stiffer spring rate itl compensate for extra weight?? am i wrong to think this ?? should i get rid at least of half of my system to have a better ride??get rid of completetly any suggestions ideas criticms will help make a decision............ thanks in advance!!
#322
A stiffer spring can be used to compensate for increased weight. But, the ride quality will suffer.
I have quite a bit of weight in the trunk due to my subs, I run 350lb springs with no issues.
#324
#325
Don't forget that there was someone many pages back in this very thread (yes I've actually read it) that was running like 8 huge batteries to power his tunes. Life must be tough at 5 or 10 kW when you're parked and not plugged into the mains...
