Suspension & Brakes Theory, alignment, spring rates....
Caster Issue Alignment
Old Feb 20, 2015 | 06:00 PM
zuptidi's Avatar
Default Caster Issue Alignment
I've been trying to perfect the alignment on my car..
This is on a 1995 Eg hatch civic
Car Has ALL new Hardrace bushings..
My RF caster is off though, need help diagnosing what could be the source.
about two months ago RF caster was a -0.3 degrees.
Here s alignment reports
FRONT
CAMBER
L -1.0 R -1.0
CASTER
L +0.7 R -0.3
TOE
L 0.02 R 0.03
REAR
CAMBER
L -1.0 R -1.0
TOE
L 0.05 R 0.06
I went ahead and replaced the UCA with hardrace setup, i could see a light bent on the pass old Skunk2 UCA i had.. I thought this would solve my issue..
Aligned it today
FRONT
CAMBER
L -1.1 R -1.1
CASTER
L +1.4 R +0.4
TOE
L 0.02 R 0.03
REAR
CAMBER
L -1.0 R -1.0
TOE
L 0.05 R 0.06
Could it be possible that the knuckle is bent giving off that caster issue??
Any input on what to check next..
I did some measuring on the LCA to check symmetry and using jack points/ tow hooks as references.. Left and right LCA had equal distance between reference points..
Any input..
Old Feb 21, 2015 | 05:40 AM
kristo's Avatar
Loved
Default Re: Caster Issue Alignment
Spec EG Caster - Measurement in degrees.
o 1.17 (range 0.17 to 2.17)
Oem parts original to the car? Any accidents? Did you clock all bushings well enough?
I had due to a straight-on hit on a pavemant a bent subframe with all other parts remaining straight.
In my experience only way to check is to replace parts with parts you are sure are straight and the check alignment.
Old Feb 21, 2015 | 11:04 PM
slowcivic2k's Avatar
Is this a Ford F-150? You need to read the forum rules and post ALL relevant information. Failure to do so will cause your thread to fail.
I'm wiling to respond if you are willing to provide DETAILED information.
Old Feb 22, 2015 | 03:25 PM
zuptidi's Avatar
my bad, i forgot
ek guy
Suspension & Brakes
Nov 5, 2008 07:11 PM
Understeer
Jul 11, 2005 05:09 AM
Yesman
Jan 31, 2002 11:01 AM
yoshi234
Dec 27, 2001 01:11 PM
keys
Sep 7, 2001 11:21 AM
