Suspension & Brakes Theory, alignment, spring rates....
Best way to add static caster on EG/DC2 chassis?
Old Aug 22, 2025 | 09:04 AM
  #26
spAdam's Avatar
Loved
Community Favorite
Default Re: Best way to add static caster on EG/DC2 chassis?
My Hardrace compliance bearings took longer than originally claimed too. Fortunately I ordered way ahead of the project.
Old Aug 24, 2025 | 06:37 PM
  #27
Belar cars's Avatar
On the EG/DC2 chassis, one of the most common ways to add static caster is by using adjustable front upper control arms or extended compliance bushings. This allows you to move the wheel slightly forward in the wheel well, which increases caster.
Another option is offset bushings for the lower control arms, but that can sometimes affect camber as well, so you need to check alignment carefully after any adjustment.
Most people looking for a more responsive steering feel and better high-speed stability go with adjustable arms since they give you more precise control. Just make sure to pair it with a proper alignment shop that understands Honda setups to avoid uneven tire wear.
Liberty.R
May 26, 2018 05:28 PM
hondamanbran
Suspension & Brakes
Jun 26, 2010 09:32 AM
GagnarTheUnruly
Suspension & Brakes
Nov 2, 2009 10:32 AM
dnatrance
Sep 7, 2004 12:20 PM
CanuckCRX
Jun 24, 2002 07:47 AM
