Suspension & Brakes Theory, alignment, spring rates....
ABS Light
Old Sep 24, 2008 | 07:56 AM
91HondaAccord98's Avatar
Default ABS Light
Hey,
I've gotten really good help from the site before and trying my luck one more time. About 6 months ago my ABS light came on but when I've had to break hard a couple of times since then, I've never had a problem with my brakes locking up. I took it to a mechanic and he told me my ABS is probably fine and it might be an electrical problem. I've checked the fuses for the ABS system and they're not fried as far as I can tell. Is there anything else I can check or do to remedy this myself? Thanks in advance!
Gregg
Old Sep 25, 2008 | 05:08 AM
lightweight_'s Avatar
the only thing you can do is take it into Honda and get it hooked up to HDS (honda diagnostic system) and see what exactly caused the light to go off. i know 4th gen accords have problems with leaking solenoids, but you cant know for sure until you look up the code.
Old Sep 26, 2008 | 04:31 PM
Default Re: (lightweight_)
Thanks for your input. I was hoping this wasn't the only solution though. Is the dealership the only place to check an ABS code?
ChesterNL
Aug 1, 2011 11:35 PM
rhino87
Mar 24, 2009 09:57 PM
f22suzuka
Apr 21, 2004 10:15 AM
steffexchik
Oct 16, 2003 04:41 PM
92LudeSI
May 31, 2003 12:51 AM
