Suspension & Brakes Theory, alignment, spring rates....
99 Civic CX disc brake conversion problems.
Old 05-17-2015, 05:18 PM
Fraser1989's Avatar
Default 99 Civic CX disc brake conversion problems.
Hey guys,
Last year I bought a 1999 civic CX. The car came with a disc brake conversion, now unfortunately I do not know what car the parts came out of.
Problem #1, my rear left brake seems to be be contacting the rotor at all times.
Problem #2 the handbrake will sometimes seize on the left side.
Problem #3 the handbrake cable on the right side dose not engage at all.
The rear rotors are pretty worn, so I am going to replace them.
I have searched disc brake conversions, and at this time it is my understanding that I can order any rear rotors and pads that are intended for a 1994-2001 integra , however I am not sure. Can someone confirm or deny this for me?
At this time I figure I might as well replace the handbrake cables. I believe that the cables from a 99 si are the best option for my car?
The proportioning valve, I am not sure if this was upgraded to the 99 si model. But at the same time I believe that when I was reading about the conversions it said that a 99 Cx proportioning valve is also a 40/40 valve?
Am I on the right track, or have I got my information mixed up?
Old 05-17-2015, 07:33 PM
phunhaus's Avatar
Default Re: 99 Civic CX disc brake conversion problems.
You are on the right track. All 88-01 non-ITR Integras and 88-00 Civics shared the exact same rear pads, rotors, and calipers. Get the ebrake cables for the 1999-2000 Si since that is the same "chassis" as your year Civic.
To make things easiest on you, consider the rear portion of your brakes a "99 Si" and be done with it.
Old 05-17-2015, 08:53 PM
9sec.rs4's Avatar
Also you probably Have a caliper locked up on the side you were grinding on, and on those the e-brake is part of the caliper so you can check the function of the e-brake while the wheels off probably bad calipers more then cables
Old 05-18-2015, 07:59 AM
Fraser1989's Avatar
Let's say this is the case. Do I fix it, or do I replace it?
Old 05-18-2015, 09:11 AM
phunhaus's Avatar
That depends on YOUR skill level.
Old 05-18-2015, 10:19 AM
Fraser1989's Avatar
Skill level 6/10.
So far I have changed the water pump, timing belt, valve cover gasket, spark plugs, Alternator belt, fuel filter, removed HID lights and changed the oil.
I have also worked on several other cars.
I have changed brake rotors in the past, but never anything else to do with the brakes. I have a Haynes manual which helps. I guess a better way of asking the question would have been, would it be better to fix the caliper or replace it? I don't know very much about how they work other than the absolute basics.
Old 05-18-2015, 04:20 PM
phunhaus's Avatar
If that's the case it would probably serve you well to replace it. An autoparts-store version will probably run under $100. Grab some fresh brake fluid, a friend, and a six pack. You should be done in under an hour depending on when you start drinking.
Old 05-18-2015, 05:32 PM
9sec.rs4's Avatar
You should be more than capable to replace the rear calipers hardest thing will probably switching the cable from the old caliper to the new one
Old 05-19-2015, 05:12 AM
Fraser1989's Avatar
Excellent, thanks guys.
Old 05-19-2015, 05:04 PM
cruizinmax's Avatar
The proportioning valve is the same on the hatch and si. Before replacing any calipers or e-brake cables you should try diagnosing the problem first. It could be something as simple as rusted caliper slider pins. Don't just throw parts at it.
Old 05-21-2015, 06:09 AM
9sec.rs4's Avatar
Proportioning valve controls fluid he's having e brake problems
Old 05-21-2015, 04:27 PM
phunhaus's Avatar
His comment was in reference to the original post.
Leviatard
06-12-2014 02:25 PM
MS1742
Suspension & Brakes
10-16-2008 10:57 AM
Diggins
10-22-2005 07:13 AM
Quick Reply: 99 Civic CX disc brake conversion problems.
