Tons of High Quality Honda/Acura parts. GT42r, Full-race, Hondata, EK/EM1
So all these parts are basically new, I did make 2 passes on the car and that's it. Everything is mounted right now, but can be pulled asap for interested people. PM or email for pics of anything you need a better look at. Willing to ship if shipping is paid for or a label is sent. I will also combine shipping if multiple parts are purchased. Paypal is accepted if 3% is added. Checks are accepted, but no product will ship or be given untill check clears, and Cash is always good.
Here's the list folks:
GSR head fully Ported with new valve seals and guides. 1900
Ferrea 1mm oversized valves, intake and exhaust
Polished combustion chambers
Ported by Ryan formally of pro-machine.
GSR Cams 75 <b>SOLD</b>
AEBS headstuds 100
SRR adjustable cam gears. 150 <b>SOLD</b>
Ls RS machine o-ringed and sleeved block. 2500
Balanced and polished ls crank with GSR gurtel and aebs gurtel studs.
Carrillo rods WITH Carr bolts! -Balanced
Custom CP pistons with oversized wrist pins. –Balanced
Hot tanked.
Moroso oil pan. 100 <b>SOLD</b>
Garrett GT4294R ball bearing turbo with polished compressor housing, and coated exhaust housing. 1900
Full-race t4 divided top mount manifold with duel 44mm wastegate flanges 1200
2 tial 44 blue wastgates with dump tubes. BLUE 300 each <b>SOLD</b><b>SOLD</b>
Tial Blue blow off valve. BLUE 200 <b>SOLD</b>
Full 4” v-band downpipe, custom made by Cortney Green 200
4” aluminum exhaust with burns muffler. 300
3 inch polished charge pipe 150 <b>SOLD</b>
Precision 1000hp intercooler 550
Eddlebrock Victor x intake manifold port matched to the head. 250 <b>SOLD</b>
Eddlebrock Victor x intake manifold machined for 8 injectrors 250
Hondata intake manifold gasket. 50 <b>SOLD</b>
blox 76mm throttle body. 200
Aeromtive fuel filter -10 50 <b>SOLD</b>
Aeromotive Eliminator fuel pump, with black aeromotive fittings. 350 <b>SOLD</b>
Aermotive Fuel pressure regulator -8 130 <b>SOLD</b>
Eddlebrock -10 fuel rail 100
Precision 1600cc injectors 300
FJO injector driver 100
-8 black nylon braided fuel feed line AND 200
-6 black nylon return line
Full-race sump and EK/EM1 gas tank. 150 tank
Hondata S300 WITH all options and p28 ecu 550 <b>SOLD</b>
AEM boost control solenoid. 75 <b>SOLD</b>
DEFI gauges with control unit. Boost, Fuel, and EGT, needs new egt sensor. 600
MSD digital 6 ignition 300
MSD Distributor 450
MSD HVCII coil 150
Power shut off switch. 50
Tech edge PRO wideband. 450
B16 tranny, freshly rebuilt with Quaife LSD 1000 <b>SOLD</b>
Drive shaft shop stage 5.9 axles, 950 <b>SOLD</b>
Tilton Twin disk clutch with release bearing and master with stainless line. 1300
Fully adjustable OMNI coilovers. 950
Omni front camber kit 100
Moroso catch can with -12 lines to valve cover and drain back. 100 <b>SOLD</b>
Avid Solid mounts. For EM1/EK 350
Fluyidyne duel core radiator. 300 <b>SOLD</b>
FAL Fan. 150 <b>SOLD</b>
Custom engine harness, all the crap removed and re-loomed. NOT Ghetto! 100
Full 12 point cage, With civic si shell attached. done by Dean./shell 5000
Stroud 5 point harness. black. 110
Stroud window net black 100
Si leather seats with blue inserts. 100
Duel gauge bezel surround . 45
SSR comps 17” wheels!! come with falken azenis, tons of life left! Original not knock offs! 2000
VIS carbon fiber hood. looks good, has a heat crack, Cheap! 200 <b>SOLD</b>
VIS carbon fiber side skirts. 150
Lenso 13” drag wheels with 24.5 Micky Thompson slicks installed, 5-6 passes. 500
Brand new interstate Battey, huge cranking amps. 80
Fully leagl stainless Battery box. 100
valvecover with 2 -12 an bungs welded on 50 <b>SOLD</b>
3" silcone couplers. with tbolt clanps 50 <b>SOLD</b>
Precision ball bearing oil restrictor 50
-10 turbo oil drain kit 50
arp oil pan blots 40
arp12 point chrome manifold bolts. Check them out on lightiningmotorsports.com 50 <b>SOLD</b>
22t waterpump 30 <b>SOLD</b>
oil pump 30
timing belt. 30 <b>SOLD</b>
shift linkage 50 <b>SOLD</b>
Thanks everybody!
Jesten Thompson
801-916-4130
Utahbmx@yahoo.com
AEBS headstuds 100
Hot tanked.
MSD Distributor 450
MSD HVCII coil 150
oil pump 30
Thanks everybody!
Jesten Thompson
801-916-4130
Utahbmx@yahoo.com
Re: Tons of High Quality Honda/Acura parts. GT42r, Full-race, Hondata, EK/EM1
Here's a few pics guys. Feel free to ask me to take a pic of anything.
S300, chargepipe, ported eddlebrock, cams, gears, tranny sold! Still have a lot of parts for you guys!
Tranny, oil pan, shift lingage, and valve cover sold! Thanks guys. All items have shipped check paypal and email for tracking numbers.
Hood sold, and I totally know linkage is spelled this way. I must have had a brain malfunction above.
Axles sold! Thanks soo much guys for helping me get out!
Last Tial WG, Bov, fuel pressure regulator, and fuel filter sold.
Also forgot to add that I have a golden eagle scatter shield and full-race traction bars!
Tracking numbers posted to paypal everyone! Thanks you!
Originally Posted by Crab-Cakes
just recived everything like 15 minutes ago and everything looks good, thanks man...
your an awsome seller!!!
Jules Winnfield
Mid-Atlantic (Sales)
32
07-19-2011 07:23 PM
DC Love
06-25-2010 08:39 AM
utahbmx
08-12-2009 01:20 PM
Yambor
06-24-2007 05:31 AM
