FS: MECHANIC IN SO CAL,MOTOR SWAPS,HEAD GASKETS,VALVE ADJUSTMENTS,TURBO INSTALL
FS: MECHANIC IN SO CAL LOOKING FOR SIDE WORK,MOTOR SWAPS,HEAD GASKETS,VALVE ADJUSTMENTS,TURBO INSTAL
LIKE THE TITLE SAYS,IM A DIESEL TRUCK MECHANIC IN SO CAL BUT I'VE BEEN WORKING ON HONDAS FOR 7 YEARS OR LONGER NOW AND LOOKING FOR SIDE WORK. I CAN DO JUST ABOUT ANYTHING, SUCH AS MOTOR SWAPS,HEAD GASKETS,VALVE ADJUSTMENTS,TURBO INSTALLS,AXLE REPLACMENT,DIAGNOSTICS,WIRE TUCK,EVERYTHING IS PROFESIONALL AND CLEAN ................YOU NAME IT AND I PROBABLY DO IT. I'LL CHARGE LESS THEN ANY SHOP AND I'LL COME TO YOU ..................... 909-749-1849 IF YOU NEED ANY WORK DONE........................ THANKS FOR LOOKING..................................
Modified by boostnhoe at 5:31 PM 11/14/2007
Re: FS: MECHANIC IN SO CAL,MOTOR SWAPS,HEAD GASKETS,VALVE ADJUSTMENTS,TURBO INSTALL (boostnhoe)
BUMP!! NEED SIDE WORK!! CALL CUZ I RARELY COME ON HT
Re: FS: MECHANIC IN SO CAL LOOKING FOR SIDE WORK,MOTOR SWAPS,HEAD GASKETS,VALVE ADJUSTMENTS,TURBO IN
i like the part where you go to the work. i will probably be needing ur services soon
BUMP!! KEEP THE PM'S COMING!!
bump lots of pm's keep them coming
ALL PM'S REPLIED AND ONE CUSTOMERS SWAP ALREADY DONE BUMP!!
