FS: JDM GSR 4-2-1 header, OBD1 Alternator, B-series Starter, OBD1 Dizzy *CHEAP PARTS*
* B A N N E D *
FS: JDM GSR 4-2-1 header, OBD1 Alternator, PR4 ECU, OBD1 Dizzy, GSR cams, MUGEN valvecover, Retainer
OBD0 PR4 LS (DOHC, manual tranny) ecu: $50
JDM GSR 4-2-1 header w/ heatshield: $120
OBD1 (B-series) Alternator: $60
B-series Starter: $40
OBD1 (B-series, VTEC) Dizzy: $130
JDM B16a (SiR-II) camshafts: $40
JDM B16a Intake Manifold and fuel rail: $50.00
JDM B16a Valves: $50
JDM SiR-G (B18C/GSR) camshafts: $80
JDM SiR-G retainers and valvesprings: $60
SOHC Mugen Valvecover (Brand New and RED): $120
JE pistons (used) and JE piston rings (new) [84.5mms; 12:1 compression]: $230
LS pistons and Rods (81 mms): $60
92-95 Honda Civic Heater Core: $50
92-95 Honda Civic Winshield wiper Motor: $40
92-95 Honda Civic Sedan rear corner lights (set): $40
92-95 Honda Civic Ignition w/ key and ignition harness: $60
92-95 Honda Civic Interior wiring harness (uncut): $100
92-95 Honda Civic Turn Signal switch: $30
92-95 Honda Civic High-beam low-beam switch: $30
92-95 Honda Civic/94-01 Acura Integra H-series HASPORT motor mounts (EGH1): $300
92-95 Honda Civic/94-01 Acura Integra Koni Orange struts and Eibach springs: $150
92-95 Honda Civic Hatchback Back seat windows: $30 each
92-95 Honda Civic 2-Door Passenger window: $50
Apexi VAFC (Grey) with harness and mounting stand: $120.00
95 JDM GSR throttle body: $25 (sensors extra)
98 USDM LS throttle body: $25.00 (sensors extra)
95 D16Z6 intake manifold with injectors and Throttle Body: $50.00
MSD Blaster SS coil (New): $20
PRICES ARE PICKED UP: KEEP THIS **** TO THE TOP HOMIES!
Modified by Equilibrium at 3:11 PM 11/7/2007
Modified by Equilibrium at 3:13 PM 11/7/2007
* B A N N E D *
Re: FS: JDM GSR 4-2-1 header, OBD1 Alternator, B-series Starter, OBD1 Dizzy *CHEAP PARTS* (Equilibri
Looking for a CLUTCH, hit me up if you got one and need any of these parts!
* B A N N E D *
Re: FS: JDM GSR 4-2-1 header, OBD1 Alternator, PR4 ECU, OBD1 Dizzy, GSR cams, MUGEN valvecover, Reta
Starter is PENDING SALE: I also have a BRAND NEW PIONEER DEH-P6800MP headunit for sale $120.00 picked up is the LOWEST I will do, located in Moreno Valley (92553), hit me up if you're interested
* B A N N E D *
Hey Vincent, thanks a lot for all the Bumpz! Glad you're happy about the deal on the bearings, if you ever need anymore skateboard equipment hit me up!
