B20b Short Block Ready For B20vtec, B20Turbo, or B20vtec Turbo!!
B20b For Sale.
Built for B20vtec, B20 Turbo, or B20vtec Turbo.
Specs: Balanced rotating assembly, acl main bearings, Acl Race rod bearings, thrust washers, Npr piston rings, Gsr oil pump, Gsr water pump, Gsr belt tensioner, Gsr timing belt, and type r rod bolts.
Assembled with assembly lube and Honda Bond.
680 o.b.o
Everything is fresh and ready to be dropped into a car.
All it needs is an oil pan.(if I find a good oil pan before its sold I'll put it on)
NOT interested in any trades.
Cash only.
This is first come first serve!!
Post on here or text me @ 909-565-8123
Pictures are below, if you need more pictures just shoot me a text.
680 o.b.o
Cash only.
Re: B20b Short Block Ready For B20vtec, B20Turbo, or B20vtec Turbo!!
So basically all I have to do is tap my head new gasget and sandwich plate and head studs tq down and call it aday?
Yes sir. That's pretty much it.
I build the blocks to be that way so its easy to drop in and drive.
Alright foshow just wonder all of the other stuff I have to buy for it. On a budget because my motor just decided to blow a rod berring out of no where revving to 9500 Rpms lol hahaha
Lol for sure.
This block has a balanced rotating assembly and acl race bearings so its gonna be kinda hard to throw a bearing
Lol but will be easy to blow a rod lol what I'm known for. Well im just waiting till my pay check comes in Tommorow.
Yes sir^ it's a bitter sour relationship with me tho lol!!!! Some times you can get them to run right and some times you can't lol
Actully found metal in the bottem end from the previous owner ****in up the head an all the shavings just ****ed everything up royaly lol
I was assuming everything else was in good working condition.
But defenately metal shavings will kill those bearings
yea everything is in great working condition but going to play it safe and get the head hot tanked to get any form of metal shavings out of it.
Shoot me a call and let me know around what time you want to come by today. 909-565-8123. I'll give you my address over the phone.
