2006 Honda TRX 450R W/all the gear.
Im posting this for a freind
Vin will be provided upon request
* 2006 Honda TRX 450R (Electric Start)
* Less then 5 hours
* Taken out for one ride in January of this year( Plaster City Ca.)
* Has never seen sand
* Has never seen rain
* Has never been into 5th gear
With the purchase of the quad:
* Sand Star Tires Mounted on Itp Standard Rims (rears only)
* Fox helmet ~ size xl
* Oakley Goggle's
* TLD Troy Lee Design Chest Protector
* Moose Exp Pants ~ Size 32
* Alpine Star Boots ~ Size 10
Every thing listed here was also only worn once!!!
There might be some other things im missing so ill update later when i find out for sure.
Price ~ 7500 takes everything listed here
SPECs:
Engine Type 450cc liquid-cooled single-cylinder four-stroke
Bore and Stroke 96.0mm x 62.0mm
Compression Ratio 12.0:1
Valve Train Unicam; four-valve
Carburetion Keihin 40.0mm flat slide with throttle position sensor (TPS)
Ignition CD with electronic advance
Starter Electric or forward kick
DRIVE TRAIN
Transmission Five-speed
Driveline O-ring-sealed chain
CHASSIS / SUSPENSION / BRAKES
Front Suspension Independent double-wishbone with Showa shocks, featuring adjustable spring preload, rebound and compression damping; 8.4-inch travel
Rear Suspension Pro-Link with single Showa shock featuring adjustable spring
preload, rebound and compression damping; 9.0-inch travel
Front Brakes Dual hydraulic 174.0mm discs with twin-piston calipers
Rear Brake Single hydraulic 190.0mm disc with single-piston caliper
Front Tires 22 x 7-10 knobby radial
Rear Tires 20 x 10-9 knobby radial
DIMENSIONS
Length 72.6 inches
Width 46.3 inches
Height 43.1 inches
Wheelbase 49.2 inches
Seat Height 32.4 inches
Ground Clearance 4.2 inches
Dry Weight 350.0 pounds
Fuel Capacity 3.2 gallons
Pics:
Please Bump If you look
Email kngfufytr@yahoo.com
Located in riverside area of socal
Modified by blkonblkcrime at 9:39 PM 10/28/2006
Modified by blkonblkcrime at 9:43 PM 10/28/2006
* Less then 5 hours
* Oakley Goggle's
SPECs:
DRIVE TRAIN
DIMENSIONS
Length 72.6 inches
Width 46.3 inches
Height 43.1 inches
Pics:
Re: (blkonblkcrime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkonblkcrime »</TD></TR><TR><TD CLASS="quote">2 </TD></TR></TABLE>
Re: (blkonblkcrime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkonblkcrime »</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Bumpo
Bumpo
Re: 2006 Honda TRX 450R W/all the gear. (blkonblkcrime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkonblkcrime »</TD></TR><TR><TD CLASS="quote">asdf!!1!1111!!</TD></TR></TABLE>
way to much..... thay are going for way under 7 grand otd and most dealers... john burr honda in fontana 6500otd with tax and licence...
Re: 2006 Honda TRX 450R W/all the gear. (aLL MoToR Eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aLL MoToR Eg6 »</TD></TR><TR><TD CLASS="quote">way to much..... thay are going for way under 7 grand otd and most dealers... john burr honda in fontana 6500otd with tax and licence... </TD></TR></TABLE>
7500 with all the gear is not bad, im sure someone will make a offer on it for less and then that's when the pirce starts coming down.
Re: (sicky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicky »</TD></TR><TR><TD CLASS="quote">you plan on replying to any of my pm's?</TD></TR></TABLE>
Sorry pm's get blocked on my comp. replied to pm
