~ Distributor and D15Z1 & D16Y8 Head and D16y8 Engine/Tranny
Located in the Valley (818) PM me a number if your interested. Sorry NO Trade
a) 90 Civic D15 Distributor, less than 3 weeks old, I still have the box $100
c) 95 Accord F22 Distributor $75
d) 92 VX D15Z1 ECU $100
e) 95 Integra GS Distributor $99
1) 00 GSR / B16A2 Distributor $125
h) PARTING OUT, LONG Block is SOLD. Selling the 5Speed Tranny, Intake Manifold, Exhaust Manifold Seperately. See List just below of this; 1998 USDM D16Y8 Engine, 5 Speed Tranny and ECU (NO harness, NO Knock Sensor) Stock 91K Miles, NO mods done. Still on the Front Clip (I can show the original cluster) Will provide Bill of Sale & Copy of Pink Slip.
1) 1998 D16Y8 5 Speed Tranny $350,
2) 1998 D16Y8 Intake Manifold Assembly, Complete with Throttle Body MAP TPS, Injectors, IACV, Injector Rail, Fuel Regulator, EVAP Sensor $175 (WONT Seperate)
3) 1998 D16Y8 Exhaust Manifold (Upper & Downpipe) $99
4) D16Y8 Distributor $75
i) 2000 Civic HB Factory B-pipe & Muffler, excellent condition. less than 50K miles of used. $175 (WONT Seperate)
j) 1998 Civic EX Factory B-pipe $99
k) 1995 Civic EX Factory B-pipe $99
Just Added 06/08/11
a) 93 Civic EX SOHC hydro tranny 5 Speed Tranny (NO Sensors), has Input Shaft bearing Noise, slight grind, not sure if was the bad clutch or syncro itself. $99 FIRM
b) 00 Civic DX Tranny, 5 Speed Tranny Perfect Condition. NO Sensors, NO Drain plugs $225 FIRM
c) 00 Civic DX Intake Manifold with TB Throttle Body Attached, NO TPS/NO Injector, has MAP and Working IACV $65 FIRM (WONT Seperate)
d) D16Y8 Alternator $55
e) D16Y8 Starter $45
Just Added 06/08/11
Re: ~ Distributor and D15Z1 & D16Y8 Head and D16y8 Engine/Tranny
PM sent. I'm usually on HAN, so that accounts for my low post count.
Lookin to see if you still have the vx head.
Just Added 06/08/11
a) 93 Civic EX SOHC hydro tranny 5 Speed Tranny (NO Sensors), has bearing Noise, slight grind, not sure if was the bad clutch or syncro itself. $99 FIRM
b) 00 Civic DX Tranny, 5 Speed Tranny Perfect Condition. NO Sensors, NO Drain plugs. $225 FIRM
