***D SERIES TURBO KIT***
got a complete D Series (get a t3/t4 Bseries Manifold and boost your B series) T3/T4 Turbo kit for sale. comes with Turbo,Manifold,Downpipe,Turbonetics Mark2 Wastgate, HKS Seq. BOV, Frontmount,piping, Manual boost controller, Walbro 255 Fuel pump , Vortech FMU, oil feed and oil return lines. EVERYTHING you need to boost. $900.
It has a 3-5lbs spring in the wastegate now but will also come with a 10-15lb spring. Turbo is perfect, no shaftplay or leaks. just decided to go Different route. For an extra $500 ill throw in BRAND NEW Mark1 Boost and oil pressure gauges, Brand New AEM Digital Wideband A/F Gauge, Brand New Greddy Turbo Timer. and Brand New RC310 injectors. so for $1400 u can have it all. Take a look and do your homework and you will see im taking a big loss. will also part out gauges and injectors.
*****DOES NOT COME WITH HONDATA******
Re: ***D SERIES TURBO KIT***
fsho. liek i said this one has everything. just need to tap ur pan. i was going to give my tapped pan with but found out the spare zc pan i have got a lil ****ed up so i had to weld up the oil tap and keep the pan. but other then that on a stock z6 or zc or even a minime u should be able to hit 200whp clean.
good ****. my boys old stock ls plus bolt ons and 12lbs put out 256whp on a good tune. i came across his old 3" DP, and maybe his Greddy Bseries turbo mani too actually. ill let you know on that
WGFletch4WS
09-23-2009 07:02 PM
Hatchamaback
05-05-2006 05:12 AM
