FS 400+ HP 2000 Civic Si North Carolina $9,500
Old 06-11-2010, 02:06 PM
LuckyToBeBC's Avatar
Post FS 400+ HP 2000 Civic Si North Carolina $9,500
The Good
Engine Block:
B18C (Around 60K miles on it )
ITR Crank
JE 9:1 forged pistons
Eagle Rods
OEM bearings
OEM Water pump
ITR Oil pump
Toda timing belt
Cometic head gasket
ARP main studs
Head:
ITR Cams
Unorthodox racing adjustable cam gears
ARP Head studs
Hondata intake manifold headshield gasket
Fully shaved valve cover
Turbo Kit:
Borg Warner S256 turbo
Extreme Parts/Love Fab ram horn exhaust manifold/downpipe/dumptube
Tial 44mm wastegate
Tial 50mm BOV
Precision 1026 FMIC
2.5" aluminum intercooler piping
3" stainless steel mandrel bent exhaust with Magnaflow Muffler
Samco couplers
Vibrant T-bolt clamps
Edelbrock Victor X intake manifold
Skunk 2 68mm throttle body
AEM 4" dry flow filter
Turbo XS Dual Stage boost controller
MSD 3-bar map sensor
Fuel System:
Walboro 255 fuel pump
Precision 780cc injectors
AEM fuel rail
Aeromotive fuel pressure regulator
Autometer fuel pressure gauge
6AN stainless fuel feed line
Hondata S300
Transmission:
GS-R transmission w/OEM LSD
ACT Xtreme pressure plate
ACT 6-puck sprung hub disc
ACT Street lite flywheel
Stainless steel clutch line
ITR Shifter w/ new OEM bushings
Suspension:
Tein SuperStreet dampers
SPC front control arms with camber adjustment ball joint
SPC rear dog bone camber kit
Energy Suspension front upper and lower control arm bushings
Password JDM front 3-point strut bar
Password JDM rear strut bar
Rota Circuit 8 sports bronze wheels 15x7
Misc Engine:
Hasport billet aluminum motor mounts
T1 Racing oil catch Box w/ 4 12AN breather hoses
Samco Coolant hose kit
Mugen Fan switch
OEM t-stat
Taylor aluminum battery box located in trunk
P28 ECU w/ boomslang conv. harness
AEM power steering pulley
Interior:
OEM factory option 2-tone leather
CTR shift boot
Alpine CDA-9883 head unit
JL 6.5" Front Component speakers
Valet alarm and keyless entry
Exterior:
CTR headlights
Tinted Windows
AEM rear big brake kit
Shaved rear emblem
The Not so Good
Ok so more about the car it does not pass emissions if you are in county that does that. It requires a waiver.
Small road rash on the front lip... also a little smudge on the rear bumper, which I am sure, can be buffed out (Wal-Mart Drivers) also a cracked taillight
Smokes a little out of the breather box, which gets pulled into the passenger side.
I also have dyno sheets and most of the receipts for this car it really is a beautiful car I am just kind of getting out of the whole tuner thing and purchasing a new car.
If you have any questions or would like some more pictures email me. mbc1104@alumni.ecu.edu
LuckyToBeBC is offline
Old 06-11-2010, 02:58 PM
JDMvirginNC's Avatar
Default Re: FS 400+ HP 2000 Civic Si North Carolina $9,500
BUMP! for a good friend...Can vouch for a very fast & clean SI!
JDMvirginNC is offline
Old 06-13-2010, 10:56 AM
bump...
Old 06-14-2010, 09:19 PM
late night bump..
Old 06-16-2010, 06:15 AM
bump..
Old 06-18-2010, 02:19 PM
bump...
Old 06-18-2010, 02:45 PM
xASAPx's Avatar
Damn super clean.. Bump
xASAPx is offline
Old 06-23-2010, 05:57 AM
to the top..
Old 06-24-2010, 08:24 AM
bump..
Old 06-24-2010, 04:46 PM
Not to be confused with "THE MAN"
THE GUY's Avatar
bump for you
THE GUY is offline
Old 06-26-2010, 06:57 PM
Bump.
Old 06-28-2010, 04:13 PM
bump..
Old 06-30-2010, 06:46 AM
bump
Old 07-02-2010, 08:36 AM
bump..
Old 07-06-2010, 05:04 AM
Bump...
Old 07-06-2010, 06:47 PM
boosted_ejcivic's Avatar
clean si................bump
boosted_ejcivic is offline
Old 07-07-2010, 03:58 PM
UASK20's Avatar
bump for nc
UASK20 is offline
Old 07-09-2010, 08:08 AM
bump..
Old 07-12-2010, 03:53 AM
Bump
Old 07-14-2010, 06:37 AM
bump
Old 07-21-2010, 08:39 AM
bump
Old 07-23-2010, 07:47 AM
bump...
Old 07-25-2010, 08:28 AM
Sunday Bump
Old 07-27-2010, 05:18 AM
xNCDUBx's Avatar
pm has been sent
xNCDUBx is offline
Old 07-29-2010, 07:05 AM
PM has been replied
Quick Reply: FS 400+ HP 2000 Civic Si North Carolina $9,500
