F/S : GSR Garage clean out ! Get this stuff out of my garage ASAP !!!!
Just like the title says , Im cleaning out my garage ! Im moving in 2 months and I need this stuff gone ASAP ! Its been sitting in my garage for WAAAAAAAAY to long collecting dust ! Everything is located in : Concord, North Carolina. Small stuff I will be happy to ship and their will be shipping fees and paypal fees and im paypal verified . The larger stuff will need to be picked up , as of lately Ive had lots of flakers ! So with that being said , YOU WILL travel closer to me ! I will not leave the state ! I will not drive over 30 min from my house ! If you want me to drive more than that , you will factor in gas money for me to travel ! I will not waste my time nor gas on bullshit or flakers !
PARTS ARE FOR SALE ONLY ! ABSOLUTELY NO TRADES ! I DONT NEED THEM OR WANT THEM .... I NO LONGER HAVE A HONDA/ACURA , SO YOUR STEELIES OR YOUR JDM FRONT LIP ARE OF NO USE TO ME !!!!! NO TRADES NO TRADES NO TRADES NO TRADES NO TRADES NO TRADES ............. IS THAT CLEAR ? ! ? ! ? ! ?
People ! If you want parts ..... PM ME ! Do not leave me your # , im not going to text or call you ! PM ME to set things up .
All parts came off my old car , a 95 DB8 . Theirs a mix of 2 door and 4 door GSR parts but all will interchange except for the obvious parts. I no longer have the car and it was totaled out and crushed ! What you see in this thread , is all that I have ! Nothing more ! So dont ask ! If you do , you WILL be ignored. All parts are as is , ask all questions before purchasing and all sales are final .
1) Comptech SS 4-2-1 header GSR/ITR with o2 sensor. Needs a new flange at the cat area . SOLD
2) RS Machine Dual core half sized radiator for all 92-00 civics. I had this in my 92 EG GSR hatch and in my 95 DB8 . If you want to put this in an integra i will include an extra radiator mount. $75
3) rear disk swap , complete with everything needed for a complete install. $175
[/b]
4) OBD1 GSR engine harness, ran in 2 different cars , has OBD2 Injector clips soldered on. - SOLD
5) Engine harness plugs with pigtails - $5 each
6) OEM 98+ Integra radio with cubby hole - $40
7) DC2 couple side skirts - $25
8) DC2 fender liners Driver and passenger - $35
Bin #1
-OEM ITR Intake arm w/Apexi intake flange. Just needs a replacement filter - $50
- B16a2 TB complete with all sensors ( MAP and TPS is damaged and needs to be replaced ) - sold
- GSR TB missing the return spring but has all sensors - SOLD
- NGK VTEC Plug wires - $35
- B&M Adjustable FPR - $35
- OEM FPR -$10
- BNIB AR Alum. Cam seal - $30
- P2R B-series TB gasket ( made out of the same material as the Hondata gaskets ) with new SS bolts - $10
- OBD1 VTEC injectors GSR/B16 - $25
- OEM Main relay $30
- Tucked clutch line with fittings. $40 THIS DOES NOT go all the way to the MC . THis is for integras only, it goes from a fitting on the fire wall to the slave cylinder.
BIN #2
- Samco GSR radiator hoses - SOLD
** NOTE : Top hose has a slit in it from my accident, would be perfect to cut down and put in a water temp gauge or for a custom setup .**
- B-Series transmission braces OEM - $10
- Motor mounts : Driver side, rear and lower torque mounts. Have Energy Suspension Inserts in them . $65
- B-Series Energy Suspension shifter bushings - $10
- Beaks rear Subframe bracing kit for EG/DC/DB - $45
- Energy Suspension 24mm front swaybar bushings and brackets - $10
- 95-97 GSR cluster with 133,XXX miles - $50
- integra cluster trim - $5
- OEM Fuel lines x 2 - $5 each
- OEM GSR Throttle cables x 2 - $10 each
- Under hood main fuse box - $15
- GSR Upper engine covers - $25
BIN #3
- OEM DB8 muffler - $40
- OEM 24mm GSR front sway bar, bushings and end links - $30
- OEM 13mm GSR rear sway bar setup with alll brackets , bushings and bolts needed for install - $50
- OEM GSR starter - $30
- OEM GSR Half shaft $40
- OEM EG/DC/DB shocks with ebay coilovers. 1 coilover is missing the sleeve. $50
[/b]
Bin #1
- OEM FPR -$10
BIN #2
BIN #3
Re: F/S : GSR Garage clean out ! Get this stuff out of my garage ASAP !!!!
Bump to the top ! I need this stuff gone. MAKE REASONABLE OFFERS ! NO LOWBALLING !
gusisboosted
06-22-2011 07:28 AM
DAprojectTuRtle
06-02-2011 09:49 AM
da93integra
12-15-2008 09:30 AM
