turboing a D17A2
Old Sep 22, 2004 | 06:04 PM
bradmanuwf's Avatar
Default turboing a D17A2
I have a Max Rev turbo kit @ 6-7 psi, vortec FMU, and the A'pexi S-AFCII for an 03 civic ex. When I put it on, will have a problem with fueling and detonation without any other modifications? A guy at a performance shop told me that I will need a "Guardian" to keep the engine from getting messed up by detonation and other fueling problems. I am just wondering if this is accurate and if I will need anything else to keep my engine running smooth with a long life? Any info on turboing my 03 civic ex will be greatful.
Old Sep 22, 2004 | 06:13 PM
Ricey McRicerton's Avatar
Default Re: turboing a D17A2 (bradmanuwf)
There's a turbo EM2 at my school, but I never manage to catch the guy out at his car between classes. I'm still stumped as to how a returnless fuel system works out with FI.
Old Sep 22, 2004 | 06:18 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: turboing a D17A2 (Ricey McRicerton)
there is a turbo kit we fixed, was on an '02 or '03 but it has 2 additional injectors with a separate driver. i dont think an FMU will work on a returnless fuel system. i am actully prett confident that it will not work. you need to read into it a little more. check the FI forum.
Old Sep 22, 2004 | 06:26 PM
Discosteak's Avatar
Default Re: turboing a D17A2 (boostedcivicsir)
since the fmu pinches a return line and you dont have one it might be hard to use your vortech fmu
Old Sep 22, 2004 | 06:29 PM
bradmanuwf's Avatar
Default Re: turboing a D17A2 (BADEG6)
the fmu came with the kit. I figured something was strange when I couldn't find a return line.
Old Sep 22, 2004 | 06:31 PM
bradmanuwf's Avatar
so larger injectors are a must to deliver more fuel? I wonder if I could use the injectors from a b series motor?
Old Sep 22, 2004 | 06:36 PM
bgoetz's Avatar
try 7thgencivic.com
Old Sep 22, 2004 | 06:38 PM
Mr. Badwrench
Default Re: turboing a D17A2 (bgoetz)
not larger, you might want to look into a pair of supplimental injectors like rev hard used to use.
Old Sep 22, 2004 | 06:39 PM
bradmanuwf's Avatar
do you think the stock fuel pump will be able to keep up with larger injectors or will I have upgrade my fuel pump too? do you know what the civic you fixed did about detonation. I'm pretty sure that the knock sensor and the computer controlled timing will adjust for it but I don't want screw up my engine.
Old Sep 22, 2004 | 06:44 PM
Mr. Badwrench
here is a post on a 7th gen forum
by the looks of it they have made it a return style fuel system with another pump. but it doesnt say anything about plumbing.
http://www.7thgencivic.com/for...26410
good luck either way.
hspoon
Aug 15, 2007 01:17 PM
civproject14
Jan 14, 2005 06:59 AM
mpociask
Jun 6, 2004 09:25 AM
dragonenchantress
May 23, 2004 09:55 AM
single cam vtecn
May 22, 2003 11:48 PM
