ECU codes
Do you guys think we can get a master thread at the top of this forum that reads all the EF OD0 ECU codes, like the EG/Del sol forum??? Since every1 is always asking wat a certain code means....TIA
Modified by yOyOshi at 9:14 AM 9/22/2004
http://www.hybridgarage.com
Look in the Tech section just off of the mainpage. All honda ECU codes are the same from 88+. The only thing different is how the ECU outputs them. Wether it be a flashing LED, CEL, or have to be read with a scan tool. Typically EF ECU's output codes my flashing a short flash for the code the ECU is seeing. the PWO/PR3 ECU are a tad different, with those a short flash =1 and a long flash = 10, just add up the flashes and you've got your code.
Well Alright thanks, anyways my CEL codes are 7 and 17, I know my VSS is bad and its out since i need to replace it, But my TPS, how do i fix that?
Did the code 7 just pop up? Or have you done a MPFI swap to it recently? A bad TPS code means the ECU is seeing a voltage that it isn't supposed to coming from the TPS or it isn't seeing a signal at all.
i have a DOHC ZC in my 88 hatch, so it does have the MPFI swap, The thing is i bough the car w/ the motor already in it and a half *** job
Im gonna buy a new harness and redo everything corectly, so wat do i have to do? thanks again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yOyOshi »</TD></TR><TR><TD CLASS="quote">Do you guys think we can get a master thread at the top of this forum that reads all the EF OD0 ECU codes, like the EG/Del sol forum??? Since every1 is always asking wat a certain code means....TIA
Modified by yOyOshi at 9:14 AM 9/22/2004</TD></TR></TABLE>
Good idea
Good idea
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16 EF »</TD></TR><TR><TD CLASS="quote">
Good idea
We should!
Good idea
</TD></TR></TABLE>We should!
ef_you_again
Mar 17, 2005 11:14 PM
