fuel psi problem on jrsc d16
Old Sep 21, 2004 | 09:36 PM
kaedingracer3's Avatar
Default fuel psi problem on jrsc d16
I am having a major problem. My fuel pressure is 40 psi at idle but when i get on it the psi only rises to 55-60 psi under boost and the motor runs extremly lean. I Have a brand new fuel filter and pump. Heres my setup.
D16a6 with darton flange sleeves
scat rods
JE pistons 8.3-1 compression
ported and polished ports and chambers
swirl polish valves
isky springs
crane cam Duration intake:232 Exhaust: 234
Jrsc with boost upgrade 10-11 psi
Short ram intake
AEM fuel rail
stosk injectors
Airmass header
2.5" exhaust with apexi N1
Intank walbro pump
Fuel psi gauge coming off of rail
Old Sep 21, 2004 | 09:47 PM
Redline130's Avatar
Default Re: fuel psi problem on jrsc d16 (kaedingracer3)
Are you using a FMU?
Old Sep 21, 2004 | 10:01 PM
Default Re: fuel psi problem on jrsc d16 (Redline130)
yea the jackson racing external one ive heard its **** though
Modified by kaedingracer3 at 11:12 PM 9/21/2004
kaedingracer3
Oct 15, 2004 08:23 AM
kaedingracer3
Sep 22, 2004 03:14 PM
kaedingracer3
Sep 22, 2004 02:43 PM
kaedingracer3
Sep 21, 2004 08:14 PM
ndmracing
Aug 30, 2001 01:57 PM
