Trying to get good at changing rear pads.. any tips?
Old Sep 21, 2004 | 05:38 PM
Chris F's Avatar
Default Trying to get good at changing rear pads.. any tips?
Preface, I hate changing brakes. But I'd like to get it down to a 30 minute ordeal
The front pads can be changed by removing the lower 14mm bolt and rotating the caliper up to show the pads. Hooray.
The rears, I have to remove the 2 14mm bolts to remove the whole caliper and it's mount. And, I have been removing the 12mm bolt that holds the brake line in place to get it around the heat shield. I made a rear-caliper-screw-in-tool with a 3/4" copper pipe and a hammer (plus a dremel to round the edges, don't want to tear the rubber!)
I also use a bent coathanger to hold the rears in the air (by the spring) to avoid pulling on the brake line.
Anyone have a better method on the rears? I saw Magic Hat #9's post about taking a bolt off of the heat shield... I think I like my way better, it has more play with more slack in the brake line. But I never tried it that way, or at least not both ways in the same day.
-Chris
Old Sep 21, 2004 | 05:39 PM
Willard's Avatar
Default Re: Trying to get good at changing rear pads.. any tips? (ccfries)
from the FAQ sticky past at the top of this page.
https://honda-tech.com/zerothread?id=157444
pix are dead... but if you copy and paste the picture link into a new window the will work.
I remove the splash shield and the caliper... then pull it back and free.
my piston tool = large screwdriver.
Old Sep 21, 2004 | 05:42 PM
Chris F's Avatar
Default Re: Trying to get good at changing rear pads.. any tips? (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">from the FAQ sticky past at the top of this page.
my piston tool = large screwdriver.</TD></TR></TABLE>
Yeah, I read that article. I guess I'll try that.
96CivicEXSedan
19
Dec 13, 2013 03:36 PM
wgbm92
Suspension & Brakes
Nov 9, 2010 07:02 AM
E-brake or Handbrake
54
Oct 11, 2004 03:02 PM
Carlo
11
Nov 18, 2003 01:21 PM
integra15
Feb 20, 2002 09:27 AM
