car wont start sometimes
Old Sep 21, 2004 | 02:24 PM
wadafa's Avatar
Default car wont start sometimes
sometimes my car wont start, it turns over, it has spark, i suspect a fuel problem,
i can hear the fuel pump kick on sometimes, and when it does, the car starts, but then it will rev up to warm up then immediately die, if i pump the gas while its dying, it does nothing, this happens a couple of times, then the car will finally starts and runs, once it runs, it has never died while i am driving,
i dont think its the pump cause when i check for fuel, and when the pump does kick on, i get plenty of fuel, could it be a relay of some sort,
its an '88 CRX hf
thanks
Old Sep 21, 2004 | 02:27 PM
Rostr02's Avatar
Default Re: car wont start sometimes (wadafa)
auto or stick? also whens the last time you changed your fuel filter? might as whell start there. its like 5 bucks .
Old Sep 21, 2004 | 02:28 PM
wadafa's Avatar
Default Re: car wont start sometimes (Rostr02)
its a stick, changed the fuel filter about 5 months ago
Old Sep 21, 2004 | 02:34 PM
4drEF's Avatar
Keyboard Humorist
You said that you hear the pump come on "sometimes".
What about when you don't hear it come on?
Seems like a typical main relay problem.
Old Sep 21, 2004 | 02:38 PM
wadafa's Avatar
Default Re: car wont start sometimes (4drEF)
when i dont hear it come on the car just turns over, no start
when i do hear it, it starts
also another problem i have, sometimes when i turn the key it does nothing no turn over no nothing, i try again then it turns over, possibly another relay
is this main relay a dealer item or can i pick it up from any auto parts store??
Old Sep 21, 2004 | 04:57 PM
Super Chicken's Avatar
Main Relay classic symptoms. It's just underneath the dash by your fuse panel against the outside of the car. I don't think you can buy one aftermarket, but is only 40-50 bucks from the dealer.
Old Sep 21, 2004 | 05:00 PM
wadafa's Avatar
thanks guys for the quick replys, i'll go and pick one up tomorrow
DelSloSiwhat?
Jun 21, 2013 05:21 PM
Perkul8r
Aug 4, 2009 10:57 AM
dxhatch93
Nov 17, 2005 01:12 PM
kuckimonster2
Jul 25, 2005 07:03 PM
spettinger
May 25, 2005 11:46 AM
