RSR exmag; stainless steel?
Old Sep 21, 2004 | 01:42 PM
streetlegal gocart's Avatar
Default RSR exmag; stainless steel?
Do they make them now in stainless steel? I know in the pictures they are coated, but some description say ss, maybe its just for the tip or muffler.
Old Sep 21, 2004 | 02:07 PM
slooogsr's Avatar
put mine on recently....... its all coated cept for the tip
Old Sep 21, 2004 | 02:09 PM
skunkintegra's Avatar
Default Re: (slooogsr)
someone correct me if im wrong...
but the old school rs*r used to be stainless.
post above is %100 correct
Slain's Avatar
i know when they were first released mid 90's they offered them in stainless or black coated. not sure if they still have the stainless applications. good exhaust tho
Old Sep 21, 2004 | 02:45 PM
sly_106's Avatar
Default Re: (Slain)
It IS stainless steel, its just coated stainless...
Old Sep 21, 2004 | 02:57 PM
kb8thekid's Avatar
Default Re: (sly_106)
yeah the old school rs*r were ss, like the post says it's still ss but it's just coated now. but to have one of the originals :drool:
Old Sep 21, 2004 | 03:21 PM
Default Re: (kb8thekid)
ExMag features
quietest exhaust note on the market (most applications)
refined stealth like appearance
ceramic coated mandrel bent piping
dyno proven gains in horsepower and torque
engineered in Japan
signature RS-R exhaust tip
constructed with 409 stainless steel for long life
Old Sep 21, 2004 | 03:22 PM
Default Re: (Doctor Zagato)
i bolded the last line. I wonder if they mean just the tip.
Old Sep 21, 2004 | 04:16 PM
sly_106's Avatar
no, the entire thing is made of stainless steel. It's just coated stainless steel
Old Sep 22, 2004 | 06:45 AM
Electron_LS-Vtec's Avatar
Default Re: RSR exmag; stainless steel? (Doctor Zagato)
My Rsr GT-II is coated stainless... so I am assuming that that one is stainless too.
Old Apr 26, 2006 | 08:21 AM
JohnQPublic's Avatar
Default Re: RSR exmag; stainless steel? (Electron_LS-Vtec)
*Back to life*
Is the RSR Exmag really all s/s (some 409ss and coated/some304ss)?
Here are the quotes from the RS-R homepage:
"Sleek in design, this exhaust systems jet-black coating hides the SUS409 stainless steel muffler and piping behind the well known. Each ExMag system is custom tailored for each application. The ExMag muffler can be either a straight through, loop or chambered design.
RS*R exhausts are made from a combination of 409 stainless steel and 304 stainless steel in both the polished and non-polished form. GT2 exhaust tips are all laser cut, to ensure that we get a perfect look, every time. All RS*R exhausts are designed for proper fitment and then tested on the in-house dyno to ensure maximum power gains."
I thought that I had read either here or team-integra people having rust issues...I need a quiet system that is not going to rust like my current setup.
Thanks,
John
Modified by JohnQPublic at 11:48 AM 4/26/2006
Old Apr 26, 2006 | 08:27 AM
Default Re: RSR exmag; stainless steel? (JohnQPublic)
I also found this quote from the Director of Sales:
"Hello,
RS-R exhaust piping is made out of a material called 409 steel. It is a
very high quality, half stainless alloy. Although we can use 304 steel
for our piping, we would not be able to create the stealth appearance of
the ExMag. You can be assured that you are getting a very high quality
exhaust, and the piping is a coated stainless steel.
Thanks,
Koji Ikeda
RS-R
Director of Sales and Marketing
tel: (310) 518-5450
fax: (310) 518-5491
e-mail: koji@rs-r.com"
So, what exactly is a half-stainless alloy?...can it rust?
Old Apr 26, 2006 | 08:34 AM
CNSK's Avatar
I have the old school Rsr exhaust stainless steel.....mine looks rusted but when I took the axle back off and used 1500 grit sand paper to sand the dirt off....still had the bling...
Old Apr 26, 2006 | 08:46 AM
tomithy's Avatar
I've heard of the rsr having rust problems which is why I chose not to get one. It's not necessarily the problem of whether its coated on the outside or not. It will rust from the inside.
Old Apr 26, 2006 | 09:17 AM
dFreezy's Avatar
Default Re: (tomithy)
Seems like people were confusing 'stainless steel' with polished stainless steel (as opposed to the newer version which is painted/coated stainless steel.
Even though its 'stainless' steel, it will still show signs of rust on the outside surface (ironic huh). they seem pretty durable throughout though from what I've read. My Greddy SP rusted out on me recently, so I'm looking for a long term exhaust too
Old Apr 26, 2006 | 12:04 PM
Rahxephon's Avatar
Default Re: RSR exmag; stainless steel? (streetlegal gocart)
about rusts....well nothting last forever it's only matter of time....RSR exmag FTW!!
Old Apr 26, 2006 | 01:54 PM
tomithy's Avatar
Default Re: (dFreezy)
It's not stainless steel. Only the muffler is stainless steel, the rest is coated mild steel. I've read several horror stories of it rusting out after 1 year. Which is why I'm going all SS.
http://www.superhonda.com/foru...77444
read there for one such horror story.
Old Apr 28, 2006 | 07:06 PM
The piping is made from 409 stainless steel (better than aluminised steel but not as rust-resistant as 304 stainless). The muffler is 304 stainless steel. Both are covered with a coating so it should be safe from rust. And, 409 stainless actually allows the surface area to form a rust covering but not eat through, it's not as pretty as the 304 but it too is good for an exhaust, especially if covered with a coating like the RS-R Exmag.
For more info on 409 stainless see--> http://www.azom.com/Details.asp?ArticleID=969
Old Apr 29, 2006 | 04:28 AM
b18sihatch's Avatar
Default Re: (JohnQPublic)
as far as the exmag and gt2, i am wondering if 409 ss is lighter than 304 stainless steel, i know that weight for these exhausts are a issue the lighter the better is what rsr is going for and to use a heavier gauge my thoughts would be 409ss is lighter yet durable. plus it being coated never hurts... my gt2 catback exhaust system is 3.2 inches in piping diameter and the whole thing weighs a total of 16lbs that is light
matttegra
Jul 9, 2007 01:43 PM
professor poon
Apr 12, 2006 12:16 PM
EK-Cruiser
Mar 16, 2005 11:08 PM
DubyaAye
Apr 30, 2004 01:09 PM
