Car Dies w/ A/C On
Old Sep 21, 2004 | 12:16 PM
billyhoe's Avatar
Default Car Dies w/ A/C On
b18c obd1 skunk2 manifold, no cat, no evap, no iab. Runs fine without a/c, with a/c on when driving as soon as you depress the clutch most of the time car will shut off right away, if not rpm will drop very low then sputter back up. Adjusted idle screw up bout 500 rpms doesnt help. Am i missing something here?
Old Sep 21, 2004 | 12:30 PM
evil_schmevil
Guest
Posts: n/a
Default Re: Car Dies w/ A/C On (billyhoe)
How much vacuum are you pulling at idle?
Old Sep 21, 2004 | 02:06 PM
billyhoe's Avatar
Default Re: Car Dies w/ A/C On (evil_schmevil)
dont know i havent check, i guess i should do that huh. Ill get back to you on that
Old Sep 28, 2004 | 07:32 AM
b16racer23's Avatar
ur alternater is going out
Old Sep 28, 2004 | 08:47 AM
ponytd's Avatar
raise your idle to like 750-800
Old Sep 30, 2004 | 05:51 PM
billyhoe's Avatar
my v-afc says -550mmhg
Old Sep 30, 2004 | 05:52 PM
billyhoe's Avatar
Default Re: Car Dies w/ A/C On (ponytd)
idle already is at 750
Old Sep 30, 2004 | 06:18 PM
jdm_cars's Avatar
I believe your problem is your IAC Valve, I have recently just did the skunk2 install myself, and I am having problems when the AC is on too. now I get a check engine light Code 14 that says IAC Valve.
Hope someone knows the answer.
BTW, did you have to extend the two wires for the iacv connector? yellow black, black blue? for some reason my was super short and wouldn't reach.
let me know.
thx.
Old Oct 1, 2004 | 09:14 AM
billyhoe's Avatar
Default Re: Car Dies w/ A/C On (jdm_cars)
i did extend the wires cutting the iac wire off another harness, but i dont get a code 14, from time to time i get a code 1 (oxygen sensor) used plenty of o2 sensors so i dont know. I've been thinking IAC because sometimes the idle would fluctuate up and down but i wasnt sure if it was the IAC causing the car to shut off with A/C on.
The Chazzer
Honda CR-V & Element
15
Sep 12, 2012 04:24 AM
typer_696
Aug 8, 2009 01:43 PM
em1gangsta
Jan 26, 2008 03:40 PM
DC2_8.2K
Mar 31, 2007 06:57 PM
