what kind of mounts do you use to put a 94 gsr into a 93 DX hatch
Old Sep 21, 2004 | 12:01 PM
mR. Vash's Avatar
Default what kind of mounts do you use to put a 94 gsr into a 93 DX hatch
as topic says...thanks..
Old Sep 21, 2004 | 12:02 PM
GAccord's Avatar
Default Re: what kind of mounts do you use to put a 94 gsr into a 93 DX hatch (GsRdHatcH)
cant go wrong with hasport
Old Sep 21, 2004 | 12:05 PM
ABK's Avatar
ABK
Default Re: what kind of mounts do you use to put a 94 gsr into a 93 DX hatch (GAccord)
Search, pretty much any b series mount except 99-00 SI (I believe).
Old Sep 21, 2004 | 12:27 PM
mR. Vash's Avatar
arent there stock ones that fit? off of like an integra or something....i thought it bolts right in without gettin after market mounts.
Old Sep 21, 2004 | 12:32 PM
mwieczorek43's Avatar
Yeah, the stock GSR mounts will work. Or even LS mounts if you got em'.
Worse yet, if you need to use your DX mounts (wouldnt recommend it) you can make those work. Good luck
Old Sep 21, 2004 | 12:36 PM
siblueg's Avatar
Default Re: what kind of mounts do you use to put a 94 gsr into a 93 DX hatch (mwieczorek43)
on my 95 dx I used the dx trans mount and rear mount, and the stock itr drivers side motor mount all with prothane inserts
Old Sep 22, 2004 | 06:45 AM
mR. Vash's Avatar
Default Re: what kind of mounts do you use to put a 94 gsr into a 93 DX hatch (siblueg)
thanks....
Old Sep 22, 2004 | 12:49 PM
siblueg's Avatar
no prob
eg_21
Jun 8, 2009 07:54 PM
xoutlawz00x
11
May 22, 2005 06:49 PM
ViXoN Hatch94
May 17, 2004 07:30 PM
emoney9
Mar 12, 2004 05:37 AM
txhatch
Sep 9, 2003 12:17 PM
