what kind of mounts do you use to put a 94 gsr into a 93 DX hatch
as topic says...thanks..
Re: what kind of mounts do you use to put a 94 gsr into a 93 DX hatch (GsRdHatcH)
cant go wrong with hasport
Re: what kind of mounts do you use to put a 94 gsr into a 93 DX hatch (GAccord)
Search, pretty much any b series mount except 99-00 SI (I believe).
arent there stock ones that fit? off of like an integra or something....i thought it bolts right in without gettin after market mounts.
Yeah, the stock GSR mounts will work. Or even LS mounts if you got em'.
Worse yet, if you need to use your DX mounts (wouldnt recommend it) you can make those work. Good luck https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: what kind of mounts do you use to put a 94 gsr into a 93 DX hatch (mwieczorek43)
on my 95 dx I used the dx trans mount and rear mount, and the stock itr drivers side motor mount all with prothane inserts
Re: what kind of mounts do you use to put a 94 gsr into a 93 DX hatch (siblueg)
thanks....
no prob
