car idling very low, missing a little, timing maybe? help please
Old Sep 21, 2004 | 11:26 AM
boostedcivichatchbacksi's Avatar
Default car idling very low, missing a little, timing maybe? help please
92 si hatch d16z6 all stock besides lightened flywheel/act clutch
i bought it salvage so i dont know the last time the timing belt was changed
heres my problem the car idles at like 200rpms, and sometimes it shakes like its about to die and the car shakes. it seems like it is misfiring also, the plugs were pretty good when i put them in (used from my old car) and my ignition is a bit retarded. i used a timing light to check the timing and the mark wouldnt stay steady. anyone lend some info, thanks
Old Sep 21, 2004 | 11:56 AM
kommon_sense's Avatar
Default Re: car idling very low, missing a little, timing maybe? help please (boostedcivichatchbacksi)
Sounds like you already found the problem.
- Advance the timing to the correct specs.
- Drop in fresh plugs with the correct gaps
- Replace bad grounds (battery, tranny, and valve cover to frame)
- Check spark plug wires with a multimeter
- Test coil with a multimeter
- Check/clean air filter
- Adjust idle (may need to check timing again after doing this)
coolswimmerjon
Sep 3, 2011 07:43 AM
GoodSpeed150
Mar 2, 2011 06:34 AM
pimpwagon
Nov 12, 2010 08:41 AM
88 EF Hatch
18
Sep 23, 2009 02:31 PM
leadfoot78
Jan 25, 2003 02:38 PM
