How do you make a Vaccum Manifold?
Old Sep 21, 2004 | 08:19 AM
adseguy's Avatar
Default How do you make a Vaccum Manifold?
Does anyone know anywhere how to make one from like Lowe's or Homedepot. Is it better to run a vaccum manifold or just tee's since I only have 3 sources that need vaccum (boost gauge, WG, and BOV). I understand that the Wastegate needs to see a good signal to operate correctly. Will a vaccum manifold be better or worse. Thanks in advance.
Old Sep 21, 2004 | 09:34 AM
EM1 MIKE's Avatar
Default Re: How do you make a Vaccum Manifold? (adseguy)
You can buy a vacuum manifold from Golden Eagle for about $35. It's up to you if you want to spend $35 to use only 3 of the 6 vacuum ports on the manifold. I'm using one and I like it, no need to "T" off any lines and looks alot less cluttered, IMO.
widewhite
Dec 30, 2014 05:55 AM
oodie
Sep 11, 2009 08:51 PM
silentdaredevil2
Welding / Fabrication
Jan 6, 2006 08:46 PM
Turbocivic94
Nov 2, 2004 08:18 AM
X-Mazda 3 Racer
May 21, 2003 08:40 PM
