Y8 in a VX????
Old Sep 21, 2004 | 06:42 AM
Convoy's Avatar
Default Y8 in a VX????
A friend of minve wants to put a Y8 in his 94 VX. He wants to know what he has to do to make it all work?? He know that hee needs to get a p28, but what else does he need? can he use the VX wiring harness? thanks in advance.
Old Sep 21, 2004 | 06:46 AM
Kyles ej1's Avatar
Default Re: Y8 in a VX???? (Convoy)
he needs the swap first of all and an obd conversion harness, cuz the y8 is obd2 n vx is obd1
Old Sep 21, 2004 | 06:48 AM
devi1man's Avatar
Convert the harness.
Edit: I got beat to it...what he said^
Old Sep 21, 2004 | 06:52 AM
Kyles ej1's Avatar
Default Re: Y8 in a VX???? (devi1man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devi1man &raquo;</TD></TR><TR><TD CLASS="quote">Convert the harness.
Edit: I got beat to it...what he said^</TD></TR></TABLE>
That's because d4 iNt3rN3t pWnZ j00!
Old Sep 28, 2004 | 07:52 AM
Convoy's Avatar
he has the motor, what else does he need??
If he uses a obd1 distributor, obd1 injectors and re-wires the O2 wire then wil it all work? or does he need to do more? thanks
Old Sep 28, 2004 | 08:50 AM
murmur9's Avatar
Default Re: (Convoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Convoy &raquo;</TD></TR><TR><TD CLASS="quote">A friend of minve wants to put a Y8 in his 94 VX. He wants to know what he has to do to make it all work?? He know that hee needs to get a p28, but what else does he need? can he use the VX wiring harness? thanks in advance.</TD></TR></TABLE>
i thought you had to use a p2p for a y8? why would you use an obd1 ecu on an obd2, i didnt know...
i always thought everything...dizzy , starter...shjould all be obd2
Old Sep 28, 2004 | 07:04 PM
Convoy's Avatar
Default Re: (murmur9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murmur9 &raquo;</TD></TR><TR><TD CLASS="quote"> i thought you had to use a p2p for a y8? why would you use an obd1 ecu on an obd2, i didnt know...
i always thought everything...dizzy , starter...shjould all be obd2 </TD></TR></TABLE>
its going in on a obd1 car
JesseBizz
Jul 28, 2009 02:46 PM
93plumvtec
Mar 26, 2008 06:18 PM
D16SiHatch
Jan 26, 2008 05:46 PM
gophat
Sep 21, 2006 08:25 PM
d1nki
Jun 26, 2006 12:44 PM
