Help needed -> rear lower ball joint
Old Sep 21, 2004 | 12:17 AM
wstef's Avatar
Default Help needed -> rear lower ball joint
I observed my lower rear ball joint becames loose.... (((((((
For front one it is possible to use legend one.
But what ablut rear??? I wouldn't like to pay a fortune for a new complete knuckle from honda....
Any suggestions are appreciated.
Old Sep 21, 2004 | 04:45 AM
Sephro's Avatar
Default Re: Help needed -> rear lower ball joint (wstef)
You can buy just the ball joint and have it pressed in. You do not need to buy the whole knuckle. I just did mine... $30 each. Check out a NAPA or similar.
Old Sep 21, 2004 | 07:44 AM
yOnKiNaToR's Avatar
Default Re: Help needed -> rear lower ball joint (Sephro)
sorry about jacking the thread, but are the front and rear balljoints the same?
Old Sep 21, 2004 | 10:32 AM
Sephro's Avatar
Default Re: Help needed -> rear lower ball joint (yOnKiNaToR)
don't know if they are the same part#... but both can be pressed in if that was your question
Old Sep 21, 2004 | 10:58 AM
staticrex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sephro &raquo;</TD></TR><TR><TD CLASS="quote">don't know if they are the same part#... but both can be pressed in if that was your question</TD></TR></TABLE>
Even the top joint on the control arm. Can that be pressed.
Old Sep 21, 2004 | 11:40 AM
Sephro's Avatar
Default Re: Help needed -> rear lower ball joint (staticrex)
yeah. I have never done it but some say it can. I just bought the whole arm because it seemed too thin to be pressed but people here say they ahve done it.
Old Sep 21, 2004 | 05:37 PM
yOnKiNaToR's Avatar
i went to a parts store and they only had listing for prelude front ball joints but no rear. could i just order 2 sets of fronts? i doubt it makes a difference but i'm just want a second opinion. thanks
Old Sep 22, 2004 | 12:46 AM
pentaq's Avatar
Here is solution:
OE part 51220-SD4-023 (European Honda Legend 1990)
Old Sep 22, 2004 | 01:36 AM
wstef's Avatar
Default Re: Help needed -> rear lower ball joint (pentaq)
Yes, I want to confirm. This old legend ball joint fits prefectly rear prelude knuckle.
It has been installed this morning
Costs about 1/5 of whole prelude knuckle
Old Sep 22, 2004 | 07:42 PM
yOnKiNaToR's Avatar
that part # is just the ball joint? is it any cheaper than a regular prelude ball joint?
Old Sep 22, 2004 | 10:20 PM
wstef's Avatar
&gt; that part # is just the ball joint? is it any cheaper than a regular prelude ball joint?
It is a separate 1990 legend ball joint you can use for prelude - it is exactly the same as the one you have in rear knuckle.
The only difference is that honda does not sell a separate ball joint for prelude, but whole knuckle. The knuckle costs about 5 times more than this legend ball joint.
Old Sep 22, 2004 | 10:28 PM
wstef's Avatar
http://www.acuraoemparts.com/ :
51220-SD4-023 JOINT, BALL (LOWER) 86 - 90 LEGEND List Price $50.90 Our Price $40.72
For prelude there is no separate ball joint, only whole knuckle (part nr 1):
http://www.trademotion.com/sch...5.gif
Price $225 for the knuckle.
gianinline
Sep 8, 2014 06:56 PM
acanby
May 23, 2011 11:35 AM
pprowler6
Mar 4, 2008 03:51 PM
Thrashed Civic
Jul 23, 2007 05:55 PM
ugotdubbz
Nov 7, 2006 03:20 PM
