Getting ready to buy another Honda but I have been out of the scene a little while and have a few ??
Old Sep 20, 2004 | 10:49 PM
ringgold's Avatar
Default Getting ready to buy another Honda but I have been out of the scene a little while and have a few ??
Alright its a 92 DX it has B18C swap with an Teg harness and a Automatic GSR Integra ECU. It originaly started up but would idle all crazy like it would rev to 4000 rpms and the surge down and keep doing it I guess. While trying to troubleshoot that problem they went to start the car back up but it wouldnt do anything. The fuel pump will not work while in the tank but they took it out and wired it straight to the battery and it ran. Could the main relay be bad??
Im about ready to get this car for a good price and this is the only problems with it other than a few other little odds and ends stuff that isnt that major. Any info that yall can give will be greatly appreciated. Also put the key into the ignition tonight and turned to try to prime the fuel pump and it did nothing we did here a slight little clicking going on somewhere.
Old Sep 20, 2004 | 11:02 PM
B16Drag's Avatar
vaccuum?
Old Sep 21, 2004 | 07:35 AM
ringgold's Avatar
Default Re: (B16Drag)
Vacuum would cause the fuel pump not to work in the tank??
Old Sep 21, 2004 | 09:19 AM
ringgold's Avatar
Default Re: (ringgold)
COuld it be the main relay and what is the best way to check this out?? Also could a ground wire not hooked up also cause this problem??
Old Sep 21, 2004 | 09:53 AM
gunnis's Avatar
Default Re: Getting ready to buy another Honda but I have been out of the scene a little while and have a fe
The main relay is notorious for going bad in the 92-95 year range.search around theres threads here. I suggest try replacing that, and check that the ground on the fuel pump is forsure connected well.good luck
Old Sep 21, 2004 | 10:07 AM
ringgold's Avatar
Thanks man I have searched around a little and noticed that many others have had some problems with the main relay.
Old Sep 21, 2004 | 10:43 AM
gunnis's Avatar
if possible go to a junkyard or find a buddy with a similar car and swap it for yours to see if thats the problem. there around $80 from honda but i am in canada.
Old Sep 21, 2004 | 11:37 AM
ringgold's Avatar
Will the relays out of a 91 hatchback work in the 92 hatchback? I dont know if this has anything to do with it but his has a B16 swap?
Old Sep 22, 2004 | 11:26 AM
ringgold's Avatar
I changed the relay wasnt it. I got into the engine bay and found a loose ground on the thermostat housing and tightened it down. It works now the car actually started but its running really ruff like all the plugs are done for.
Old Sep 22, 2004 | 11:31 AM
ringgold's Avatar
Old Sep 22, 2004 | 11:40 AM
ringgold's Avatar
Old Sep 23, 2004 | 12:15 PM
ringgold's Avatar
I changed the plugs and it fired right up. The only problems now is it has a surging idle when i start it until it reaches a certain tempurature and I dont think the vtec is working? SHouldnt be that big of a problem though it runs great other than those 2 problems
88CRXJ
26
Apr 19, 2017 12:37 PM
karrar55
Mar 20, 2011 03:13 PM
jasoncanseeoh
May 8, 2010 01:21 AM
Si2See
Oct 15, 2008 05:30 AM
stevescivic
Jul 3, 2004 06:48 PM
