Can I go ahead and install shocks/springs and then camber kit later?
Old Sep 20, 2004 | 08:17 PM
Elemental's Avatar
Default Can I go ahead and install shocks/springs and then camber kit later?
I got my shocks and springs in finally and i want to install them for a fun saturday night. My camber kit should be coming in about a week afterwards.
My question is will the camber kit install be any more difficult if i dont do it all at once... and just install shocks and springs?
Koni Yellows, H&R Race springs, and soon to be omni camber kit. Thanks. I get the concept of this, but wanted to check with all my knowledable honda friends.
Old Sep 20, 2004 | 08:29 PM
..::91TEG-G2::..'s Avatar
Default Re: Can I go ahead and install shocks/springs and then camber kit later? (Kyoushu)
you'll be fine, just dont do any crazy driving k? until you have the correct camber kit. just take it easy, then get ur camber kit, and take corners at 50+
Old Sep 20, 2004 | 08:33 PM
shyboy817's Avatar
u'll be fine for a bit, make sure u get it on asap and not be like me..thought i was doing fine...then my inner tire camber wear'd like a biaa...now my innter camber is bald and middle tire is 80% thread... oh well it's fixed now
Old Sep 20, 2004 | 09:09 PM
Elemental's Avatar
thanks cool guys.
i will try to post pics of my car the night i get it done.
Old Sep 20, 2004 | 09:20 PM
Ti3d in's Avatar
Default Re: (Kyoushu)
Do it all at once. You gotta take off the shock/springs again to install the camber kit.
Old Sep 20, 2004 | 10:41 PM
shyboy817's Avatar
i did not have to take off shocks and spring to install camber kit... all u take off is the upper control arm (uca) not really hard..didnt even take those off when i removed my shocks/springs
Old Sep 20, 2004 | 10:50 PM
b-power's Avatar
patience is a virtue. do it all at once.
Old Sep 21, 2004 | 06:26 AM
Default Re: Can I go ahead and install shocks/springs and then camber kit later? (b-power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b-power &raquo;</TD></TR><TR><TD CLASS="quote">patience is a virtue. do it all at once. </TD></TR></TABLE>
it's his money, let him do what he wants.
bottom line, get the camber kit installed soon, and dont do any agressive driving in the time being..
Old Sep 21, 2004 | 06:35 AM
threatcon13's Avatar
New User
Default Re: Can I go ahead and install shocks/springs and then camber kit later? (..::91TEG-G2::..)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. &raquo;</TD></TR><TR><TD CLASS="quote">
bottom line, get the camber kit installed soon, and dont do any agressive driving in the time being..</TD></TR></TABLE> Just because its his money doesn't mean you should recommend that he install his suspension w/out a camber kit. You don't have to drive "aggressive" to cause some bad inner tire wear if your camber is out of spec.
Old Sep 21, 2004 | 09:11 AM
RallyRedGT-V6's Avatar
Default Re: Can I go ahead and install shocks/springs and then camber kit later? (Threatcon13)
first thing everyone needs to know..camber does not wear tires NEAR as much as toe in does...
dont wait til saturday night if your gonna do this..get up nice n early, make some breakfast, and be prepared to spend all day doing this, unless somehow your in the one percent of us that do not have siezed bolts...
your gonna have to pull your suspension apart again once you get the camber kit, so you might as well just wait...besides..your toe in is gonna be way the hell off when your done, and you can burn through most of your tread in a week, even with grandma driving....just be patient and wait for it
Old Sep 21, 2004 | 10:35 AM
Elemental's Avatar
all right. that sounds like a good idea. Ill just wait for my camber kit.
lazyxazianxboi
Nov 1, 2004 08:32 AM
Quiks66
Sep 26, 2004 01:11 PM
JMod
14
Feb 16, 2004 08:43 PM
ilikemyaccord
Sep 5, 2003 10:04 AM
SilverAccord
Aug 14, 2001 05:44 AM
